PC Board resistor
Alonzo · 6898
Offline Alonzo
on: December 21, 2014, 03:37:00 PM
Getting along on my Smash build, my .27 ohm resistor reads .6 ohms (shorting my Fluke reads .1).  I put it in anyway assuming it was Ok but thought I'd ask since it's almost 50% out.  Will it make much of a difference in the filament voltage?
Alonzo
Reply #1 on: December 21, 2014, 03:42:23 PM
It can be very, very, very hard to measure low resistances like that, even factoring in the meter lead resistance.
What does your meter say when measuring the 0 Ohm resistor supplied?
Reply #2 on: December 21, 2014, 03:54:57 PM
My Fluke meter (175) has a resolution of .1ohm with an accuracy of ±(0.9% + 1) so a couple of ohms is the practical limit you can measure down to.
P.S. Never heard of a 0 ohm resistor before, whats that do for you?
Reply #3 on: December 21, 2014, 04:17:19 PM
The 0 Ohm resistor just acts as an insulated jumper.
Offline Alonzo
Reply #4 on: December 21, 2014, 04:20:38 PM
The 0 ohm measures .1 ohm, which is my zero since I get .1 ohm shorted.
Alonzo
Reply #5 on: December 21, 2014, 04:41:42 PM
Yeah, I wouldn't worry too much about it.  Oils from your fingers, oxides on the resistor leads, etc. are going to influence this low of a resistance reading.
If your voltage checks end up being off, let us know and we can revisit that resistor.
Offline Alonzo
Reply #6 on: December 21, 2014, 06:08:46 PM
Ok, Great!
Alonzo
