Stereomour vs. Tucker 45...?
faithintruth · 24700
Online Paul Joppa
Reply #30 on: January 16, 2015, 06:09:41 PM
...In another thread the question of a suitable Magnequest output transformer and plate choke came up. The question is at present still unanswered.
Now it's answered, Mike is not going to do a suitable transformer.
Offline faithintruth
Reply #31 on: January 26, 2015, 04:58:14 AM
That the Stereomour is configurable as a 45 amp but 2A3's can also be rolled in is a huge option for me. Thanks to everyone for sharing.
Reply #32 on: February 09, 2015, 03:57:10 PM
PJ,
 Here is a quote from you:
"The design is optimized for the 2A3; to run a 45 the power supply voltage is dropped about 30 volts by increasing a power supply resistance. This resistor gets pretty hot! Significantly increasing the heat under the chassis is not recommended without changing the layout, and perhaps increasing the ventilation area - i.e. to do so reliably is not a minor alteration.
For conservative operation, I recommend running the 2A3 as if it were a 45 - much easier to do."
(The above is exerted from a January 2015 posting)
I think I'll avoid the major alterations and go for the Tucker 45
