Bottlehead Kits
Crack
Quick cap question
Quick cap question
Jimb0
1716
Jimb0
Sr. Member
Quick cap question
January 16, 2015, 02:41:56 PM
Just received my film caps today. I just wanted to verify that these will be replacing the two caps by the speedball. Does orientation matter? Also, if I wanted to add wire to lengthen it what colors should I use? Thanks.
Jimb0
Sr. Member
Re: Quick cap question
Reply #1 on:
January 16, 2015, 05:51:38 PM
N/m I got it now
Now to find a way to secure them in place
orson
Jr. Member
Reply #2 on:
January 17, 2015, 06:55:23 AM
Most common solution is to secure them with zip ties attached to zip tie holders. These holders can be screwed to the top plate, directly or with standoffs, or glued with epoxy. When you google "Bottlehead Crack Caps" you will find pics.
Mac with Audirvana | Audio GD Reference 5.32 | Bottlehead Crack | Beyerdynamic T1
Bottlehead Kits
Crack
Quick cap question
