Quick cap question
Jimb0 · 1720
Offline Jimb0
on: January 16, 2015, 02:41:56 PM
Just received my film caps today. I just wanted to verify that these will be replacing the two caps by the speedball. Does orientation matter? Also, if I wanted to add wire to lengthen it what colors should I use? Thanks.
Offline Jimb0
Reply #1 on: January 16, 2015, 05:51:38 PM
N/m I got it now :)
Now to find a way to secure them in place
Offline orson
Reply #2 on: January 17, 2015, 06:55:23 AM
Most common solution is to secure them with zip ties attached to zip tie holders. These holders can be screwed to the top plate, directly or with standoffs, or glued with epoxy. When you google "Bottlehead Crack Caps" you will find pics.
Mac with Audirvana | Audio GD Reference 5.32 | Bottlehead Crack | Beyerdynamic T1
