got the vinyl itch
aragorn723 · 26650
Offline aragorn723
on: January 19, 2015, 03:20:34 PM
Hi,
I have been thinking about getting into vinyl (which might sound strange to most for a 34 year old guy).  Anyways, I got an old Linda Ronstadt album on 33 years ago at a garage sale, and was amazed by the sound.  I would like to try it again, but don't have a turntable anymore (and don't really want to spend money to try it).  My main stereo is the Quickie feeding a large SS amp, but have an Onkyo HT unit with a phono stage and a Sony TA series from the 70's with a phono stage.  Starting to digress a bit, but does anybody know of a way to get a record player for free or for a relatively low cost?
Dave
« Last Edit: January 19, 2015, 03:26:50 PM by aragorn723 »
Reply #1 on: January 19, 2015, 06:31:33 PM
Yard sales, or "estate" sales - the kind with a card table in front of the garage. Goodwill/salvation army/etc.
None of these will know whether it works or not, so be prepared to fuss with repairs or have your own yard sale a few times. Don't get changers, their mechanism is more likely to be broken and impossible to fix.
I'll wait for Josh to set me straight on these comments ...  :^)
Reply #2 on: January 20, 2015, 02:48:10 AM
You might have to clean the table/changer up a bit.  There are sites dedicated to cleaning, lubricating and adjusting Dual changers, which I recommend.  If you end up with a Dual (often United Audio on the base) I can  post one or two links to them.
« Last Edit: January 20, 2015, 01:13:04 PM by Grainger49 »
Reply #3 on: January 20, 2015, 03:33:30 AM
I've also had an in cling to get into vinyl but know very little about tables and phono pre amps to know where to start.  My only memorys of vinyl was every time my sister broke the needle i got the blame.
Now if Bottlehead could come up with a DIY turntable kit, that would be awesome!
Reply #4 on: January 20, 2015, 04:24:06 AM
You missed that one.  It was dropped.
Reply #5 on: January 20, 2015, 05:18:26 AM
Well, "that one" (the Bix) was not really something we came up with. It was one that was offered by DIY HiFi Supply and we were just a dealer for a little while. It was a really nice table that had some unfortunate speed control and spares availability issues. I'm used to being able to address the kinds of issues it had directly and that was not possible as a dealer, so we decided to send customers directly to DIY HiFi Supply for one instead.
That was like 10 or 12 years ago and it looks like they have revamped the turntable concept completely since then. One issue with the original was the bearing installation and finish, and it looks like they have a much more refined one now. I haven't looked at the product in many years, and what they have now looks very interesting.
http://www.diyhifisupply.com/opcart/index.php?route=product/product&path=179_145&product_id=1510
Reply #6 on: January 20, 2015, 06:17:38 AM
Dan, I have to agree.  That looks very little like the Bix that was sold many years ago.
Offline Chris65
Reply #7 on: January 20, 2015, 11:31:19 AM
There's been a bit of buzz about these guys http://uturnaudio.com, basic model at $179.
Offline aragorn723
Reply #8 on: January 20, 2015, 03:44:17 PM
Thanks for the replies.  A few years ago I found a technics sitting on the side of the road, just itching to get picked up.  Are turntables pretty easy to work on?  I'm somewhat mechanically inclined, and like tinkering with things..  Guessing there isn't too much to them, basically a motor to spin the record, a switch to turn it on, some kind of pot to adjust the speed, and then the needle and a mechanism to bring the sound to RCAs (which may be the complicated part!).  Sounds like it might be a fun project.
Dave
Offline Chris65
Reply #9 on: January 20, 2015, 05:59:30 PM
Depends. Older 60's & early 70's gear tended to be pretty much mechanical but as transistors became more common, then things started to get a bit more complex, with Direct drives, speed control servos, etc. But there were also simpler belt drive designs, which are quite simple in concept.
Nothing complicated about getting sound out - wires from the cartridge to the phono stage (a Bottlehead, of course ;D).
Offline Paully
Reply #10 on: January 21, 2015, 01:58:28 PM
Part of the problem of getting into vinyl on a trial basis is the expense of the ancillary items like a weight gauge, record cleaner, alignment jig, stylus cleaner, etc...  To me one of the cheapest ways to do it is to buy a direct drive P-mount turntable off of ebay.  Doesn't eliminate all the other stuff you will want and need but it gets you up and running easily and quickly and then you can decide from there how far you want to go.
See if there are any vinyl aficionados around you who can help you out to start.  It really helps.
Offline galyons
  • Geary Lyons
Reply #11 on: January 21, 2015, 03:03:58 PM
snip....
IMO, the best advice.  Why get one of the very same cheap TT's that killed analog?  Plus you really don't have enough "software" to justify the hardware.  Go listen. Go learn. Put away the wallet!  Analog does not have to be expensive, but the TT and phono stage must be at least a couple of notches above "mass consumer" grade to really get an inkling of why some of us NEVER left our analog rigs.  Even worse, "free" may be worth less than the cost of acquisition, if your experience/opinion is formed based on the sound of inferior sources.
Of course...YMMV, if you just want to hear Linda for "$#!Ts & Giggles"!!
If you are any where near the SF Bay area, come on over!!!! You could hear a Thorens TD150, Thorens TD124, Empire 208, Pioneer PL41 or the "Big Rig"!!!
Cheers,
Geary
Offline wullymc
Reply #12 on: January 21, 2015, 03:23:49 PM
Now now Geary, you're just making us jealous with all those TT.  okay....I'll take the TD124 off your hands for you! ;)
Once you go into vinyl it is a slippery slope.  If I were going to do it again I would buy a new cheap tt like the U-Turn Orbit that you know there shouldn't be any problems with and is set up well.  Keep that for a year or two and then see if you want to up the ante with a more expensive table.  That is just my opinion.
Take care and have fun with the journey!.....Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Offline aragorn723
Reply #13 on: January 21, 2015, 03:24:49 PM
"Part of the problem of getting into vinyl on a trial basis is the expense of the ancillary items like a weight gauge, record cleaner, alignment jig, stylus cleaner, etc..."
What are all these things for?  Admittedly, I don't know much about vinyl, except how to play one  8)  My dad is into vinyl, but i'm not sure how much he would know about the more esoteric stuff.  (Can't remember what he has, but it might be a music hall).  For now i'm ignoring the phono stage, and would use the one built into my onkyo ht receiver (eventually if  it is something i really enjoy, maybe a reduction would do the trick).  That was the goal, to give vinyl an honest to goodness try without spending much of anything.  One really neat thing about listening to vinyl, for instance Linda Ronstadt, is the quality of the bass.  It is hard to describe, but seems deeper and tighter than with analog equipment.
Geary,
What price range are we talking about here for a decent turntable?  Just checked Craig's list in the free section, and there are some records being given away for free!  (Pink floyd, Zepplin...).  Maybe that's a good way to start a decent collection.  Sadly though, I don't get out to the left coast much, that does sound like fun!
Dave
Offline galyons
  • Geary Lyons
Reply #14 on: January 21, 2015, 04:12:36 PM
Dave,
The entry price can be pretty cheap.  But you have to know what is a bargain and what you are just moving from their dust bin to yours!!!  With a little bit of knowledge you will recognize the opportunity buy/freebie!!
The early Japanese TT's with wood bases, metal plinths and and solid arms can be found with patience. Think Sansui, Pioneer, JVC, etc.  belt drive tables.  Look for fully manual, no auto cueing, return or changers,  Avoid the plastic crap with spindly arms.
Talk to Dad!!  No need to get esoteric. Our local CL* occasionally has vintage Japanese, Rega, Music Hall and other entry level "high end" tables for low entry cost..$100 with cartridge.  The vintage Japanese tables, here, go quickly, but they pop up for free to $100.  Garage sales and thrift stores often have a gem in the junk. If you see records at a garage sale, ask if they have the turntable!  Plan on buying a new belt.
Let folks on the list know where you are or visit.  Surely someone will want to impress you with their rig!!  :P
Cheers,
Geary
* Gotta bet the Hipsters to them!!!  ;D  They have driven the prices way up!!
