Build problem dayton 0.01 400v
jwrossie · 3707
Offline jwrossie
on: January 27, 2015, 12:29:44 PM
I am building my Reduction as we speak. Everything went pretty smooth ... until the last moment.
I was soldering the stack of dayton capacitors near the A tube, which was a bit of a difficult angle.
When the soldering was done, I looked at the stacked capacitors near the B tube and ... I hit the stack with my soldering iron :( .
One side was already done, the other lead was stil free.
I did measure it (put my multimeter on ohms and after that to volts dc and then you need to see the voltage gradually discharging).
I know the capacitor is gone  :( .
But I can't find the same capacitor (Dayton 0.01 400v) in the Netherlands (Europe)
http://www.daytonaudio.com/index.php/where-to-buy/
Is a replacement from bottlehead my only option?
Reply #1 on: January 27, 2015, 03:39:58 PM
Yeah, that sucker is fried. A tight tolerance 0.01uf polypropylene cap rated for at least 200V will work in its place, or you can email replacementparts(at)bottlehead(dot) com regarding replacements.
Offline jwrossie
Reply #2 on: January 27, 2015, 11:32:53 PM
Thank you PB, I sent an e-mail to that address.
Let's hope the parts will get here fast, so I can finish this amp  :).
