The business end of my crack
Nathan · 5351
Offline Nathan
on: February 01, 2015, 01:28:55 AM
Here's what you see-
Crack with Speedball
Padded down volume control
Teflon audio bypass caps
Mundorf MCap Supreme power supply bypass cap
Cardas RCA input jacks
PEC 100k Stereo log potentiometer
Here's what you don't see- Tung Sol 5998 and Mullard CV4003
Crack/Speedball & SEX 2.1/C4S
Offline Jimb0
Reply #1 on: February 01, 2015, 07:15:07 AM
Awesome mods Nathan!
Offline Nathan
Reply #2 on: February 01, 2015, 07:45:30 AM
It's only awesome if it sounds good. And yes, it sounds terrific! Mated with Sennheiser HD600 with Cardas headphone cabling
Offline Jimb0
Reply #3 on: February 02, 2015, 07:59:02 AM
Good to hear. What do you think of the cabling? Did you notice any differences?
Offline Nathan
Reply #4 on: February 02, 2015, 08:31:55 AM
Not night and day- plus the stock cable is much lighter; lighter is more comfortable
Reply #5 on: February 02, 2015, 10:19:36 AM
Nathan,
Nice work.  I like the woven cover to the Mundorf leads.  I don't have that kind of thing so I use heat shrink.  I got a box of different sizes really cheap.
I have been using a K72P-6 KK Teflon in my Paramours for a looooong time.  It was an improvement over the stock cap.  And way back I got in on a group buy another Bottlehead organized for Paramour owners.  Only on Bottlehead do I find a community like this.
Offline Nathan
Reply #6 on: February 02, 2015, 12:10:00 PM
Thank you! I was able to buy a roll of the woven cover for under $1. I have more than I'll ever use and I  figured why not. The big issue was what color to choose. I picked blue cause the wires are white, red and black. Needed a little blue. The bypass caps were a real find and inexpensive as well.
This is a pretty cool community-
Offline Nathan
Reply #7 on: May 09, 2015, 02:41:47 PM
Ok- added another mod- put a 270 ohm choke (Triad C7-x) in the power supply. I needed to use 1 inch standoffs and drill 2 holes in the top plate. Unsoldering the 5w 270 ohm resistor and soldering the choke's leads was a little tight but not bad.
As usual - now I'll say I'm done.
The choke is a good mod
So here's what I'm running-
Speedball, padded down volume with PEC volume pot, cardas RCA jacks, choke in ps, Teflon audio bypass cap, mundorf bypass cap in the ps
Typical tube compliment is Tung Sol 5998 and Mullard Cv4003 but now I'm using a GE 6as7g and a Mullard 12au7 (these are my backup tubes and decided to switch them in for a while to great effect)
« Last Edit: May 09, 2015, 05:37:51 PM by Nathan »
Offline Nathan
Reply #8 on: May 11, 2015, 03:07:38 PM
Triad choke mounted on 1 inch standoffs
Ok- so I replaced the 1st PS cap with a 470uf 250v Nichicon, eventually going to replace the 2nd PS cap similarly. The final PS cap is going to be interesting
« Last Edit: May 13, 2015, 12:21:43 PM by Nathan »
Offline ZacharyP
Reply #9 on: May 13, 2015, 02:24:22 PM
Getting nice and stuffed in there!
Offline Nathan
Reply #10 on: May 13, 2015, 03:20:16 PM
Here it is with the 470uf PS caps for caps 1 and 2
Yes- pretty busy in there
Offline Nathan
Reply #11 on: June 20, 2015, 05:07:14 PM
One more thing added- Switchcraft headphone jack.
Am I done now?
Offline jwrossie
Reply #12 on: June 21, 2015, 09:15:45 AM
Great mods, but I  have a question about them. I would like to do some of those mods myself, but I wandered how do you connect them and what components have to be removed? I have a crack with speedball now.
Do you have a drawing or detail photo's?
Can you describe the sound?
Offline Nathan
Reply #13 on: June 21, 2015, 09:33:06 AM
The sound is great- detailed, not harsh, plenty of depth
Some mods are straight swaps- new part for the old part. Bypass caps are another story.
The new RCA jacks made no difference. The speedball made a big difference as did bypassing the audio caps
Offline Nathan
Reply #14 on: June 21, 2015, 10:53:30 AM
I moved the speedball boards to do the new headphone jack because I lengthened wires. The boards were replaced to their original positions. The most challenging installation space-wise was the choke. See my photos in this thread to see the installation
