Quickie + PJCCS - lost bass
danielehn · 9845
Reply #15 on: April 02, 2015, 01:04:08 PM
What voltages do you get at OA and OB?
Offline danielehn
Reply #16 on: April 03, 2015, 09:03:02 AM
Will do a complete voltage check tomorrow and post the result. Forgot to shut it off earlier today and the batteries are getting a bit drained.(Recharging the 9v batteries now)
I really appreciate all the help.
Offline danielehn
Reply #17 on: April 04, 2015, 09:55:59 AM
Hi,
Here is the voltages for my quickie.
A1, 3,2V
A2 26,1V
A3, 0V
A4, 26,1V
A5 1,9V
A6 26,1V
A7 3,2V
B1 3,2V
B2 28,6V
B3 0V
B4 28,6V
B5 1,9V
B6 28,6V
B7 3,2V
T1 0V
T2 1,9V
T3 0V
T4 1,9V
T5 0V
T6 18,7V
T7 28,4V
T8 0V
T9 9,5V
T10 0V
PJCCS
IA 38V
IB 38V
OA 26V
OB 29V
Resistance
Terminal 1-5 , Just as described in the quickie manual
Terminal 6-10 , No connection at all
Reply #18 on: April 04, 2015, 05:00:53 PM
Your voltages do look good.
It's possible that there's a flaky solder joint giving you all this trouble as well, I've had a bad solder joint allow for proper voltages but awful sound on more than one occasion.
Reply #19 on: April 04, 2015, 05:10:20 PM
Since the tube voltages are OK, the problem is likely to be before or after the tube.
Offline danielehn
Reply #20 on: April 05, 2015, 08:49:26 AM
Hi,
I discovered that if I tap one of the tubes when the amplifier is on, it doesn't give the clean ringing noise that the other tube does (makes a scratching sound). I replaced the tube and the sound improved a bit. Still a little lacking in bass but much better drive and sounds over all cleaner.
Much happier now  ;D  ;D
Also finally switched the wiring to the d cells instead of forcing them into the holders.  8)
Could the lack of bass be some how be related to the sensitivity of the power amplifier?
Reply #21 on: April 05, 2015, 09:45:42 AM
Weak bass would happen if the power amplifier input impedance was low - say, 10K or lower. Or if teh 2.2uF capacitors were replaced with something smaller.
Offline danielehn
Reply #22 on: April 19, 2015, 08:52:50 AM
I think it's actually fine now :) Just a tad thin sounding. But guess it's just as much the fault of the power amplifier (50k impedance).
I'm thinking about building an external tone control unit with 2x ALPS pots
"http://www.eleccircuit.com/wp-content/uploads/2010/06/Passive-tone-control-circuit.jpg"
I would solder decent quality cabling directly on it making it more like a cable with a tone control in the middle.
Is it a crazy idea ? :) , I don't want to fiddle around inside the quickie
Reply #23 on: April 19, 2015, 02:13:03 PM
You would really want to put that in front of the Quickie, not between the Quickie and the power amp.
