Right channel pops and cracks but no sound. [Solved]
Samsquatch · 11141
Offline Samsquatch
on: February 23, 2015, 06:58:50 AM
I really wish I wasn't here with an issue but here I am. I've had13 two weeks or so of no problem listening and then Friday the right channel started popping and cracking and now there is nothing but said pops. I swapped tubes, no change, turned off the Smash, no change, swapped inputs and speakers it's still the same. I reflowed probably all the solder on the right side. I checked the resistances over the whole board and just checked all the voltages again and this is what I got. I also did the chopstick test, which I noticed someone mentioned to another member, and was not able to see any changes while I poked and prodded around the connections. Here goes for voltages, and as you'll see the right side is low at a number of points.
1. 0V
4.15V
5. 16V
7. 15V
12. 0V
13. 15V
14. 16V
15. 404V
16. 0V
17. 0V
18. 62V
20. 106V
21. 100V
22. 374V
23. 105V
24, 25,26,27. 0V
28. 62V
29.104V
30. 104V
31. 345V
32. 0V
33. 0V
34. 415V
35. 207V
36. 206V
37. 0V
38. 0V
39. 409V
40. 0V
41. 0V
42. 16V
43. 408V
44. 103V
45. 358V
46. 0V
47. 376V
48. 0V
So you can see the drop off on the right channel voltages, but I have no idea where to go from here.
Help please, going through music withdrawl.
MIke
« Last Edit: February 26, 2015, 07:26:04 AM by Samsquatch »
Mike
Winnipeg
Stereomour II   Seductor/Smash  Crack HD650 HD700
Rega Planar P3 Reduction Ortofon Bronze
Nuforce DAC 80
Fostex FE126EN in DIY backloaded horn enclosures
Best sounding system I've ever owned
Offline Samsquatch
Reply #1 on: February 23, 2015, 03:05:04 PM
Would I be wrong to think the capacitor that hooks up from 43U to 42U the 450V 22uf is toast and causing a larger voltage drop than it should be? I should be able to source one here if this is the case.
Mike
Winnipeg
Nuforce DAC 80
Offline Samsquatch
Reply #2 on: February 24, 2015, 07:29:11 AM
Yep, I was wrong. Tested the cap and it's just fine. Any ideas?
Mike
Winnipeg
Nuforce DAC 80
Reply #3 on: February 24, 2015, 07:48:55 AM
Check the screen stopper resistor soldered to the A side 9 pin socket.  When the amp is running, you can also measure the voltage at A9 (carefully).
Offline Samsquatch
Reply #4 on: February 24, 2015, 03:23:13 PM
Yep, that 237Ohm 1/8w resistor between A8 and A9 is open. So what would cause this? And are they hard to find?
Thanks PB
Mike
Winnipeg
Nuforce DAC 80
Reply #5 on: February 25, 2015, 03:40:22 AM
They aren't that hard to find, we can send you one for the cost of postage.
The resistor self-sacrifices if there is a flaky solder joint or component failure that would otherwise toast the EL84 and/or plate choke.
On one of the original Seductors, I didn't solder one leg of an MJE-350 well enough, and that resistor popped when the MJE-350 loosened up sufficiently.
Offline Samsquatch
Reply #6 on: February 25, 2015, 07:14:55 AM
We had a couple 240 Ohm 1/4W 1% at work. Is this rating going to be an issue? I might be able to sort some proper ones around here if so.
Mike
Winnipeg
Nuforce DAC 80
Reply #7 on: February 25, 2015, 10:05:41 AM
That's close enough.
Offline Samsquatch
Reply #8 on: February 26, 2015, 05:24:42 AM
New resistor installed and the music plays on. Thanks for the help once again folks.
Mike
Winnipeg
Nuforce DAC 80
