Blkout · 9203
Next I would double check the "I" and "O" pad wiring. The "I" pad should be fed from T2 or T4, the "O" pads on each board will go to T1 or T5. Swapping these can cause some issues.
Try reheating the center leg of the MJE-350 on the offending board. Put your soldering iron tip on both the center leg and the PCB at the same time, then count to ten.-PB
You can try swapping the small PC boards side to side to see if the high voltage follows a board (I suspect it will).-PB
If it matters, the resistance checks fail at T7, T9, B3, B6, all are supposed to be 2.9K Ohms, I'm getting over 2M Ohms and it continues to climb.
The resistance checks change pretty significantly with the Speedball installation.-PB
