First you should do a resistance test. If you have completed that then you should touch up the solder joints for the heaters. If the 6080 is glowing then the solder joints there (the ones that form the jumpers to the 12AU7) might be bad and the solder joints on the 12AU7 might be bad.
The tube socket is new, but may be old. The tube is new, old stock. So try removing and re-inserting the tube a dozen times to get the socket and tube pins cleaned (not the best cleaning but cleans surprisingly well).
Try those and report back.
