FP 2 one channel out
Guest · 23945
1108
on: April 14, 2015, 04:08:16 AM
Yes I'm still using my FP 2 I built in 2004.
Up to this point it has been working great, no issues.
When I went to use it yesterday one channel wasn't working. If I put my ear right up to the speaker, I occasionally hear a slight static buzz. It doesn't change if I increase the volume, and no other hum, buzz, ect.
So far I have:
Verified it's the FP
Checked the RCA plug
Checked the selector switch
Checked the volume pot
Checked the tube
There's no obvious signs of a failed component or broken connection.
Any suggestions on what to do next?
Richard
Reply #1 on: April 14, 2015, 04:21:02 AM
I had the same problem a few years back, my dear old FP 2 totally dead!  I didn't have any voltage out of the transformer so I posted and got a part number for a transformer from PB.  Ordered it but then discovered my solder on the power switch had fallen off.
In those days they had no holes in the lugs on the power switch.  I just "stuck it on" with solder.  I drilled a hole and resoldered it.  No problems since.
Since I told you that story, try the voltage checks.  If you don't have them I can give you guidance.
It is such a sweet sounding simple circuit we can knock it out today.
1108
Reply #2 on: April 14, 2015, 04:52:11 AM
Thanks Grainger.
It is a sweet sounding. After all these years I haven't found a reason to get something else.
I'll take a closer look at the connections. I should have the manual around somewhere. If I don't I'll get back to you for the info.
Thanks again.
Reply #3 on: April 14, 2015, 06:19:52 AM
You'll really need to measure voltages to know what might be going on.
1108
Reply #4 on: April 14, 2015, 06:23:34 AM
working on it. looking for the manual.
1108
Reply #5 on: April 14, 2015, 08:20:19 AM
A8 reads 0 volts. Everything else checks out fine.
Reply #6 on: April 14, 2015, 08:58:16 AM
What is the resistance reading from A8 to the ground bus?
1108
Reply #7 on: April 14, 2015, 09:50:24 AM
I get 30K.
Reply #8 on: April 14, 2015, 12:00:58 PM
Do both halves of the 12AU7 light?  Can you swap tubes to see if the 0V reading switches sides?
1108
Reply #9 on: April 14, 2015, 12:14:09 PM
I did swap tubes and tried a couple of others, same channel didn't work.
« Last Edit: April 14, 2015, 12:15:52 PM by 1108 »
Reply #10 on: April 14, 2015, 12:54:45 PM
I'd check to see if both halves of the 12AU7 glow on that side.
1108
Reply #11 on: April 14, 2015, 03:58:47 PM
Looks like only one half of the tube on the bad side glows. I switched tubes just to confirm.
Reply #12 on: April 15, 2015, 12:52:36 AM
Then check the connection at tube pins 4 and 5.  That is what jumps the two halves together.
1108
Reply #13 on: April 15, 2015, 02:17:31 AM
Well, 4&5 are connected and I'm getting the proper voltage. Is it possible the tube socket is bad?
Reply #14 on: April 15, 2015, 06:28:55 AM
It is not very likely that the socket is bad.  But not impossible.  I would check voltage from tube pin 4 to 9 then pin 5 to 9 from the top of the socket.
It is also possible that the tube socket is a little dirty.  Simply remove the tube and insert it a dozen times.  It is worth a try.
