Final Voltage Check
Forte · 22686
Offline Forte
on: June 07, 2010, 12:13:25 AM
Hi,
Have just finished soldering my amp and am up to the final voltage check.
The manual states
Quote
"It should not climb higher than about 9 volts and should then drop to zero. If it climbs much higher and/or does not reduce to zero do not plug in headphones until you have worked out the issue and the voltage stays below 9V."
How much higher is much higher?  My amp climbs to 15V and the drops to 0V, is this too high?
All over check are fine, no voltages out by more than 10% and have triple checked all parts and connections and cannot see any errors.
Jon
Crack/Speedball
Reply #1 on: June 07, 2010, 04:33:06 AM
This is probably due to variations in the spec of the 6080. Sometimes they need to cook in a bit to settle to their nominal performance. Try letting the amp run with the volume turned down all the way and without headphones plugged in, for a couple of hours. Then turn it off and let it cool for maybe 15-20 minutes and do the test again.
Reply #2 on: June 07, 2010, 06:01:43 AM
You may also have a meter with a very high refresh rate, and you are catching the peak better than we did when we wrote the manual.  The real key with that terminal is that the voltage spike is low and dissipates quickly.  If you measured there and found a constant 50v or something along those lines, it would be a good indicator that one or both of the 2.49k resistors were not hooked up properly.
Offline Forte
Reply #3 on: June 08, 2010, 12:26:52 AM
Well I left it on for a few hours and retested and no difference, but after reaching 15V it drops to 0V in seconds so all seems good. Will give it a listen later.
Thanks for your reply's!
Jon
Crack/Speedball
Offline tdogzthmn
  • Industrial Designer
Reply #4 on: June 09, 2010, 12:47:43 AM
My turn for questions!
So I got the amp build and I went through the resistance check which looked good so I proceed to the voltage check where I ran into issues.  Each terminal designated to have a voltage of 90 or 170 caused my meter dial to peak out.  All the terminals which are supposed to be zero seemed fine as the meter did not move.  Any idea of where to start looking?  I did a brief lookover to see how it compared to photos.  Also looked for unsoldered parts and any obvious shorts.  I will do a more thorough inspection in the morning but wanted to ask anyway.
Thanks for the help,
Tom
Offline tdogzthmn
Reply #5 on: June 09, 2010, 07:21:59 AM
I have one of the newer kits with the corrections.  The multimeter I am using is an older Leviton and is not digital.
Reply #6 on: June 09, 2010, 07:23:35 AM
What scale is the meter set on?
Offline tdogzthmn
Reply #7 on: June 09, 2010, 08:04:31 AM
I have the meter set to 500 DCV which is the highest setting in the DC range.
Reply #8 on: June 09, 2010, 08:19:02 AM
Then there is something wrong.  I'll bet you guessed that.  It could be the meter, do you have a friend who has a newer meter?
I don't have the information on the Crack so I don't know it produces over 500V DC.
Are you measuring to the ground or chassis?
« Last Edit: June 09, 2010, 12:00:52 PM by Grainger49 »
Offline tdogzthmn
Reply #9 on: June 09, 2010, 08:43:16 AM
I am going to grab a digital meter from a friends to double check. I was doing my readings with the black lead clamped to terminal 12, the one listed in the manual. I give an update soon once I get the new meter and try it out.
Offline tdogzthmn
Reply #10 on: June 09, 2010, 09:55:24 AM
I got the new digital meter and recheck the terminal readings.  These are the results.
Terminal
1  143.5
2  163.5
3  0.023
4  168
5  74
6  .03
7  148
8  0
9  99
10  0.00
11  0.012
12  0.00
13  170
14  0
15  193.5
19  91
20  -0.01
I found a bit of a loose connection on A1 so I am going to resolder but I did chack and the reading was not 90.  Hopefully someone might be able to know whats going on with these readings.  Thanks for the responses so far!
Reply #11 on: June 09, 2010, 11:06:25 AM
A loose connection at A1 would explain most of this.  Voltage at terminal 1 is high because no current (well, very little) is being drawn through the plate loading resistor between terminals 1 and 2.  That plate voltage also sets the bias for one half of the 6080, so I'd expect things to fall into line when that connection is remedied.
After fixing your connection, is terminal 1 closer to 75v?  Did the voltage at terminal 7 come down a bit?  99 isn't so bad, but 148 is a problem.
Offline tdogzthmn
Reply #12 on: June 09, 2010, 12:08:08 PM
I did a resolder on A1 and rechecked the Terminals but did not get any significant changes.  The terminals which have significant readings were: 1 (143.5), 7 (148), 19 (91), 20 (-0.01).
Here are the readings from the tube pins.  Also noted that only the LED on connection A3 was lit, the LED between A8 and the center was not.
A1  74
A2  0.0
A3  1.583
A4  -0.0
A5  -0.0
A6  148*
A7  0.01
A8  0.002*
A9  -0.001
B1  150*
B2  170
B3  149.2*
B4  74.2*
B5  170.2
B6  99.3
B7  -0.001
B8  -0.001
Reply #13 on: June 09, 2010, 02:12:05 PM
Check to see if the LED at A8 was installed backwards or has a cold solder joint.
Offline tdogzthmn
Reply #14 on: June 09, 2010, 03:05:45 PM
The LED was a bit loose and made sure the connection was correct (silver band facing the center pin as in the photos).  I added more solder and took new readings but I still have zero volts and A8.  Also should both lights be on or off?  Right now only one is lighting up.
