Stupid Rookie Mistake
ssenesy · 3672
Offline ssenesy
on: May 01, 2015, 05:23:53 AM
So, my S.E.X came in the mail the other day and after a quick parts inventory, I got to building.
I painted the power transformer bell end, and figured the plate choke frames (PC-3) would look really good with a hammered pewter finish.  Thus my goof - I started to remove one of the plate frames BEFORE reading the forums that this is a really bad idea.  I immediately stopped, but I did exert some force on one side to pry the frame away from the primary.
Is there any way to check/measure the chokes (all I have is a volt/ohm meter) to see if it's still good, or should I just call Bottlehead and order a couple of replacements?
Thanks in advance.
Stan Senesy
Reply #1 on: May 01, 2015, 05:31:56 AM
If the lamination stack looks undisturbed it's probably OK. What can happen is the I lams in the choke can shift relative to the E lams, messing up the gap dimension. That can change the inductance of the choke, and you would need an inductance bridge to check it. As long as you didn't pull the channel frame off completely you are probably OK.
Offline ssenesy
Reply #2 on: May 01, 2015, 05:35:50 AM
Thanks Doc for the quick reply.  I'm noticing a gap in the stack on the end, but am not sure if that was there before I attempted my surgery.  I've attached a pic.
Reply #3 on: May 01, 2015, 06:26:56 AM
If it's just that outside lam it's not a big deal.
Offline jbarnhardt
Reply #4 on: May 01, 2015, 09:15:56 AM
FYI it's a little time consuming but not too hard to tape off the rest of the choke structure (everything except the frame you want to paint) with blue tape and then you can easily spray paint it. That's what I did and it turned out great. A way to still get your hammered pewter finish without removing the frames. Enjoy, it's a really enjoyable kit to build.
-John
Reply #5 on: May 01, 2015, 09:59:43 AM
Thats what i did too, you can actually get the tape to slide in under the sides of the outer frame so you have a nice clean edge.
Offline ssenesy
Reply #6 on: May 01, 2015, 12:07:24 PM
Thanks everyone.  This has been very informative.
I've got the painters tape out and I'm masking things off right now  :)
Offline debk
Reply #7 on: May 01, 2015, 01:30:40 PM
Stan
I don't know what choke is in the SEX kit, but if you damaged it I may have one at home you can have.
Email me if you want me to look at what I have.
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline Adrian
Reply #8 on: May 01, 2015, 11:44:08 PM
Ditto on the masking off and then painting - takes patience but works great.
For my units I paint the top plate, install the hardware. mask what I don't want to paint, and then paint again.
Adrian C.
Offline JamieMcC
Reply #9 on: May 02, 2015, 01:13:54 AM
Another easy option is vinyl wrap I covered the chokes on my Sex with some as a easy way of matching my carbon top plate. Six months on it shows no signs of coming off.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fcdn.head-fi.org%2F0%2F04%2F900x900px-LL-040bc7d5_036.jpeg&hash=aecff419db9ddb9a94399228f66f5f231d84fa88)
« Last Edit: May 02, 2015, 01:15:52 AM by JamieMcC »
Offline debk
Reply #10 on: May 02, 2015, 02:48:41 AM
nice!
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Offline ssenesy
Reply #11 on: May 03, 2015, 05:13:13 AM
Thanks Deb.  I think I should be ok but I appreciate the help.
 JamieMcC, I love the carbon-fiber look.  I agree, wraps are a great way to go.  I've used them a lot in some non-electronic projects that I've done.
Stan
« Last Edit: May 03, 2015, 05:16:36 AM by ssenesy »
