Suitable cover for base
Jeb Jeb · 3360
Offline Jeb Jeb
on: May 16, 2015, 11:09:59 PM
Dear bottleheaders,
My first post.  ;D  Hello to all.
 I'm just getting started on my kit this week and planning to work on the wooden base first.   I think I'd like to add a cover to the bottom of the unit so I was wondering what would be suitable to use -  I have some 5mm perspex sheet and if I put plenty of ventilation holes in it would that be acceptable to use or should it really be metal or wood to withstand the heat?
I thought the clear perspex might be nice - kind of like an open-back watch case!
Advice Much appreciated!
Jeb.
« Last Edit: May 16, 2015, 11:35:56 PM by Jeb Jeb »
James Barker,
UK
Offline Chris65
Reply #1 on: May 16, 2015, 11:46:28 PM
It is!
Reply #2 on: May 17, 2015, 02:33:45 AM
For safety sake a metal cover should be wired to the safety ground.  This in case you have a dangling component that touches it.
I think any polycarbonate will be fine.
Offline Jeb Jeb
Reply #3 on: May 17, 2015, 04:15:19 AM
It is!
Chris, lol, - thats awesome looking, that's definitely what i'll do!
May I ask-  I've never drilled through perspex before - is it prone to cracking?  I'm guessing you start with a pilot hole then work up gradually?
Thanks Grainger - perspex it is!
James Barker,
UK
Offline Chris65
Reply #4 on: May 17, 2015, 05:07:14 AM
Don't know, but wouldn't think so if you go slowly. I got mine cut to size & the holes drilled by the perspex supplier, cost very little.
It's 3mm btw.
Reply #5 on: May 17, 2015, 06:16:59 AM
Acrylic is very prone to cracking when drilling.  When you buy the piece, ask for cast material, as it machines much better.  When you drill it, put a piece of plywood behind it and drill through the acrylic and into the plywood.
For making larger holes, use a Forstener style drill bit.
Offline Jeb Jeb
Reply #6 on: May 17, 2015, 10:06:28 PM
Thanks guys - very helpful!
All the best,
Jeb.
James Barker,
UK
Offline Gerry E.
Reply #7 on: May 18, 2015, 09:22:21 AM
For anyone not wanting to DIY, I recommend these guys:
http://www.plasticworksusa.com/home.php
I once had them make me the black bezel that goes around the REL Precedent tuner faceplate (the one I acquired was missing this).  Plast!c Works! did a perfect job and the price was more than reasonable.
Gerry
