Hi,
I am having an issue with a pop of varying intensity--from annoying to alarming--when I turn off an amp connected to my Smash with SmashUp. Correct shut down sequence is being followed (amp, then preamp). My first thought is that it was something with one or both of my Paramounts, which it still could be, maybe. Thing is, I get the same pop with my SEX 2.0 downstream of the Smash, and I don't get the power down pop on either amp when a Submissive is in the chain in place of the Smash. Hence my suspicion that it is the Smash.
I redid the voltage check from the SmashUp manual. They are spot on on the right channel and just off for the left. Here are the distinctions:
1. All the voltages that should be 150 +/- 1% are 149.9 for the right channel and 147 for the left. So 2 % off instead of within 1%.
2. All the voltages specified as 3 to 5V are 4.16 in the right channel and 4.56 in the left. So, within spec but not matched.
My question then, are these differences enough to cause a pop on shut down of the power amp while the preamp is still on? & if so, how do I correct it? I tried a different 4p1l in the off channel and got identical voltages. I only have the 6sn7 that shipped with the SmashUp, so I haven't swapped that one out. if the voltage discrepancy isn't such that it would cause this behavior, where should I look next? I can look at amps too, but the fact that it happens with two different amps made me investigate the Smash first.
Brent
