No sound - All LEDs suddenly stopped ligthing
sjeffrey · 6042
Offline sjeffrey
on: June 24, 2015, 04:52:28 PM
I'm having issues with my crack/speedball.
I've been a happy user for almost 2 years now using it for a couple of hours a day.  Earlier this week I went to use my crack and there was no sound.
I checked the obvious things like DAC input, volume, sound card, etc.  Convinced it was my crack I carefully turned it over and turned it back on.
That's when I noticed none of the LEDs are lighting.  The 2 tubes are glowing so it seems they are getting power.  The amp wasn't moved or hit or anything before it stopped working.
Tonight I figured I had a bit of time to trouble shoot so I pulled out my DMM and went to work.  Well the voltages dont make any sense.  It's a cheap DMM but it did the job just fine for my initial build.  Maybe things are really out of wack?
EDIT: I forgot to mention that a visual inspection doesn't reveal anything that looks of concern.  No obvious blown capacitors or anything.
It would be great if could get some guidance on what to do next.
« Last Edit: August 30, 2016, 03:14:28 PM by sjeffrey »
Offline Strikkflypilot
  • Shellac fiddler
Reply #1 on: June 24, 2015, 06:49:39 PM
I think You need to post the voltages. Stock by the way?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline sjeffrey
Reply #2 on: June 25, 2015, 12:37:58 AM
That's the problem. When I try to get readings the voltage is all over the place and not stable at all. I was hoping there would be a component that would cause something like that.
The amp is stock with speedball upgrade. I also tried different tubes with same results.
  • Shellac fiddler
Reply #3 on: June 25, 2015, 03:50:50 AM
Maybe a bad solder joint right at the power input?
« Last Edit: June 25, 2015, 05:17:24 AM by Strikkflypilot »
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline sjeffrey
Reply #4 on: June 25, 2015, 07:50:36 AM
Which power input are you refering to?
The tubes light up so I doubt there's an issue at the main power cord.
I ordered a better DMM (Fluke 117) so hopefully I will receive that shortly and be able to provide better readings.
In the meantime I appreciate any ideas.
Stephane
  • Shellac fiddler
Reply #5 on: June 25, 2015, 09:22:17 AM
If the tubes light up like they did before, chances are the heaters are getting around the right voltages. Have You really measured all voltages and they are all wrong?
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline sjeffrey
Reply #6 on: June 25, 2015, 10:48:06 AM
I had my DMM on DC and tried to mesure a bunch of terminals with the negative lead on T2 and the readings were just all over the place.
Nothing was remotely stable and sometimes the number would be negative.
I figured it was either really screwed up and didn't want to leave the power on too long or it could be my DMM that's too cheap.
Stephane
Reply #7 on: June 25, 2015, 11:00:25 AM
Terminal 2 isn't a ground.
When you say they are all over the place, are they all over the place on the full volt scale, or millivolt scale?
Offline sjeffrey
Reply #8 on: June 25, 2015, 11:04:31 AM
I probably meant 12, I am going from memory.
The dmm readout would jump to different numbers constantly. The decimal would show low voltage numbers to thousands and even to negative.
Reply #9 on: June 25, 2015, 11:07:16 AM
Those are the meter struggling to resolve what is basically 0V.
A loose black wire would create a disruption in the ground path to terminal 12, which would cause all of this.
Terminal 20 is the first ground point in the power supply.  Carefully measure the voltage from 20 to 21 (it may be somewhat live, even with the amp off, as the tubes are unable to siphon off the voltage).
Offline sjeffrey
Reply #10 on: June 25, 2015, 11:53:11 AM
Well I think we are on to something here.
With it powered off for over 16 hours the reading between 20 and 21 was at 2 and was slowly going down. Turning it own it climbed to just over 2 and hover there.
Reply #11 on: June 25, 2015, 12:13:48 PM
2v? 2Mv? 200V?
Offline sjeffrey
Reply #12 on: June 25, 2015, 12:14:49 PM
Sorry 2V
Offline sjeffrey
Reply #13 on: June 25, 2015, 12:50:34 PM
Ok. I just tried again after letting the types heat up a little and voltage was steady at 240V between T20 and T21.
Reply #14 on: June 25, 2015, 01:07:18 PM
The voltage will appear instantly between T20 and T21.
240V means that it's not making it to the tubes themselves.  You have a loose wire or a flaky solder joint in your amplifier preventing this most likely.
