aluminum plate
aragorn723 · 3096
Offline aragorn723
on: July 08, 2015, 01:20:48 PM
Hi,
Is there somewhere I can buy an aluminum plate similar in size to the Quickie plate?  I would like to re-purpose an old quickie wooden frame and make an amp switcher with it.  Thanks,
Dave
Reply #1 on: July 08, 2015, 01:31:00 PM
If you don't mind drilling your own holes, http://www.onlinemetals.com
Otherwise Front panel express...John
Offline ALL212
Reply #2 on: July 08, 2015, 02:26:02 PM
If what you're looking for resembles this:
http://bottlehead.com/smf/index.php?topic=8082.0
Let me know.
Aaron Luebke
Offline aragorn723
Reply #3 on: July 08, 2015, 03:06:51 PM
Let me know.
That's the idea, except i'm going to make a switcher for amplifiers to hook up to one pair of speakers.  Looks like that might be a lot of holes to drill though..  Got a drill press, I just never used it before.
Dave
Offline ALL212
Reply #4 on: July 08, 2015, 03:26:58 PM
I cheat.  I work at a metals distribution facility.  We've got a laser that cuts like butta!
If you work up a drawing in dwg (front panel designer can export to dwg) and let me know what metal you want I can run a quote.  For comparison sake I just had them price me up a Crack plate but on a  10" x 12" in .08 aluminum - around $50 + shipping.  I do need a drawing to get a quote.
That's raw aluminum - no finish at all.
Aaron Luebke
Offline JamieMcC
Reply #5 on: July 08, 2015, 08:37:37 PM
ebay is the easy answer lots of different sizes available to choose from A4 300x200mm etc its only thin and will drill easily with a pilot hole followed by a stepper cutter for holes and a jigsaw will cut it easy enough with a metal cutting blade. Cover up with masking tape draw on your centres and head to the drill press  :)
« Last Edit: July 08, 2015, 09:38:30 PM by JamieMcC »
Reply #6 on: July 08, 2015, 11:37:28 PM
Let me know.
This looks like he could buy an aluminum cookie sheet and cut it to size.
Reply #7 on: July 09, 2015, 12:00:12 AM
Paully built a scratch 45 amp.  His top plate is steel, 1/4" thick and weighed 35 pounds.  He wanted something that would not bend.
« Last Edit: July 10, 2015, 03:02:21 PM by Grainger49 »
Offline aragorn723
Reply #8 on: July 10, 2015, 02:19:03 PM
Holy crap!  That's probably overkill for this project lol.  I might have to try out the drill press, it's been sitting in my Dad's garage for a few years now.  It might have to come with us when we move :o  Would 6061-T6 aluminum be a good choice for this?
Dave
Reply #9 on: July 10, 2015, 03:03:54 PM
Dave,
No, Holy Crap, I made a bad typo.  It was 1/4" not 1.4".
« Last Edit: November 16, 2015, 12:03:23 AM by Grainger49 »
Offline aragorn723
Reply #10 on: July 10, 2015, 03:44:49 PM
I was referring to the weight.  That's the weight of a chassis for most components.
Dave
Reply #11 on: July 11, 2015, 01:19:10 AM
Oh, he was tilting it and taking readings yesterday with it on.  I'm sure he was sweating from the voltages as well as the weight.  There is a lot of iron on the 35 pound plate.  I would guess it is an easy 50 pounds.
