Mid scoop
tsingle999 · 14374
Offline tsingle999
on: August 07, 2015, 03:13:59 PM
The midscoop dial on my tode has 9 turns instead of 3. Did i do something wrong?
Bottlehead Stat headphone amp
Reply #1 on: August 10, 2015, 05:31:34 AM
 There is a series of holes around the shaft of the switch that set the number of positions by inserting the tab of the tabbed washer into the corresponding hole. To fix it, turn the switch all the way counterclockwise, remove the switch from the chassis, move the tabbed washer to position 3, then reassemble.
Offline tsingle999
Reply #2 on: August 10, 2015, 12:12:29 PM
