OT8 for 8 ohm question
ramalamadingdong · 6455
Offline ramalamadingdong
on: November 12, 2015, 12:20:05 PM
I wired according to the manual, but upon reading the directions further, it looks like the wiring is backwards. I'd have to cross the wires over themselves or reverse the transformer. Anyone else have this issue? Did I wire the trans former backwards and not realize it? Help! I've come so far!
Reply #1 on: November 12, 2015, 01:00:08 PM
There was a batch of OT-1s that had backwards lugs. This was a while ago, though, and those transformers got labels specifying the error. Can you provide pictures of what this looks like?
If I knew who you were, I could look up your order and figure out if it was old enough to be possible...
Reply #2 on: November 12, 2015, 02:24:40 PM
july of last year
They had the labels, but they said to follow the wiring directions for the transformer, which I have. Should I just turn them around then?
« Last Edit: November 12, 2015, 02:27:00 PM by ramalamadingdong »
Reply #3 on: November 12, 2015, 02:58:03 PM
july of last year
If the wires are going to the correct numbers that are molded into the bobbins, then you're good to go.  I do not believe that wire length will be much of an issue, I would not turn them around.
Reply #4 on: November 13, 2015, 05:06:32 AM
Sounds like I got it right then. I've checked the numbers 2 or three times. I may be going slow, but I'm going carefully!
Reply #5 on: November 13, 2015, 05:57:51 AM
You're doing it right! Enjoy the process.
