Twisted pair cable in reduction
Yvanyvan · 5578
Offline Yvanyvan
on: November 15, 2015, 04:20:52 AM
Hello everyone!
I am currently building reduction, but not from the original kit, so I struggle to find shielded twisted pair required. I'm quite new to diy audio so sorry for the stupid question.
The question is - can I use two-pair shielded twisted pair and remove excessive pair or maybe there are some other quick alternatives?
Ps I do not want to order the cable online as the delivery cost and time are too high.
Thanks in advance!
Ivan
Offline Tom-s
Reply #1 on: November 15, 2015, 06:00:47 AM
When using a quad type cable it's just as easy to solder the ends into pairs and use it that way.
Reply #2 on: November 15, 2015, 07:10:17 AM
I'm not clear on this, but it sounds like you are maybe attempting to build a copy of one of our products. If that is the case, I am sorry to say we cannot offer any tech support.
Offline Yvanyvan
Reply #3 on: November 15, 2015, 08:40:47 AM
I've purchased partly finished (almost not started in fact) kit from a friend with some parts missing and original assembly manual from you
Reply #4 on: November 15, 2015, 09:57:46 AM
Ah, OK. In that case, yes, you can use two-pair cable and just connect the matching colors at each end so you end up with the equivalent of two wires in the cable.
Offline Yvanyvan
Reply #5 on: November 15, 2015, 10:16:47 AM
Thanks for support!
