Blown Fuse on Crack
kelvintam · 2275
Offline kelvintam
on: January 29, 2016, 08:32:33 AM
I ordered 220VAC Power Transformer as I am in Malaysia.
I have completed soldering the parts.
I did my checks on the resistors and the values are pretty close. The 0's read as 0.
If its any help, the label on the transformer read: 2 x 150v 35m ADC transformer (doubler), 6.3v 3arms
Then, when I went on the do the voltage check, the fuse bew twice on me. Pls troubleshoot for me. And also what value for replacement fuse should I get. Could it be that the value for the fuse is  110v as opposed to the 220 that I need?
Thanks for your help.
Offline fullheadofnothing
Reply #1 on: January 29, 2016, 09:07:55 AM
Is the transformer labeled 240?
Is this a stock Crack, or is the Speedball installed?
The provided fuse is a 1A 250V fast blow. Slow or fast is fine. The same fuses are sent worldwide. You said you blew two fuses, so what did you get for a replacement?
Can you post pictures of your build?
Offline kelvintam
Reply #2 on: January 29, 2016, 10:17:31 AM
I dont see any 240 on the transformer.
This is a a stock crack. No speedball.
I have yet to buy a new fuse as I am unsure what to get.
Reply #3 on: January 29, 2016, 11:29:51 AM
That's a 120V label. Presumably it is a 120V transformer. When was this kit ordered? By whom?
Offline kelvintam
Reply #4 on: January 29, 2016, 03:17:06 PM
It's Order #12693. And I have PM the details to your inbox.
« Last Edit: January 29, 2016, 04:03:17 PM by kelvintam »
