Submissive questions to a new Quickie, Quicksand owner
frank bare · 19344
Offline frank bare
on: February 21, 2016, 08:03:32 AM
I wonder if anyone can say how the Submissive sounds compared to the Quickie?
I have both, Quickie/Quicksand, want to build the Submissive.
So, curiously, How does it sound?
And, source inputs;
I have a Hagerman Bugle Phono with 40b gain, will there be enough gain?
And I assume,a CD has plenty of output gain, so not a problem?
Any and all comments are most appreciated, thank you,
Bare
« Last Edit: February 21, 2016, 03:20:23 PM by bare »
Reply #1 on: March 10, 2016, 06:25:51 AM
You could use all three together!
Offline mkane
Reply #2 on: March 10, 2016, 06:59:38 AM
  The Submissive would go in the middle ie; after the pre-before the amp?
Reply #3 on: March 10, 2016, 07:03:56 AM
It would go in front the of the Quickie. You could just turn the volume up all the way on the Quickie to effectively turn it into a fixed resistor. Then the Submissive becomes the volume control. A lot better sounding volume control.
Offline aragorn723
Reply #4 on: May 18, 2017, 03:23:24 PM
If you do decide to build the submissive, please share the results of your system with the submissive vs. without!
Dave
