Kaiju voltage [resolved]
mpdd · 7592
Offline mpdd
on: March 20, 2016, 11:44:59 AM
I'm building a Kaiju, I'm stuck at the Driver Test. "A" side IA, OA and 32U voltages are within specification, "D" side IA voltage is fine, however, "D" side OA is 356, recommended range is 297-303. The potentiometer on "D" maxes out at 160.1 when testing at 46U.
I've tripled checked my wiring, diodes and resistor values. Does anybody have any ideas?
Any help is appreciated.
« Last Edit: March 26, 2016, 07:05:47 AM by Caucasian Blackplate »
Offline ebag4
  • Bottlehead and GR Research, Yeah Baby!
Reply #1 on: March 20, 2016, 12:04:02 PM
On page 64, the 2nd instruction on that page, did you attach to D2 or D8, it should read D8.
Best,
Ed
GO CARDS!!!
Offline mpdd
Reply #2 on: March 20, 2016, 12:27:25 PM
Thank you, I should have stated that I made the correction.
Offline fullheadofnothing
Reply #3 on: March 20, 2016, 03:02:46 PM
Swap 5670s and see if it follows the tube.
Post pictures of the top and bottom of the offending board.
Offline mpdd
Reply #4 on: March 20, 2016, 05:39:47 PM
I have switched tubes from side to side and tried a pair of NOS 396A's to no avail.
Photo's attached
Reply #5 on: March 20, 2016, 06:24:42 PM
Offline mpdd
Reply #6 on: March 21, 2016, 02:16:35 PM
Here are the photo's. The black conductor just broke from 26U as I lifted the board for the photo, that's why it's disconnected.
Offline ebag4
Reply #7 on: March 21, 2016, 02:59:04 PM
Im certainly no expert, but if I were looking for a potential cause for a low voltage situation my guess would be the center solder joint in this portion of your pic.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fs20.postimg.org%2Fdrtv4u44d%2Fimage.jpg&hash=7d5fea993d8f5833be59a3b069f45793578e53e7)
Good luck,
Ed
« Last Edit: March 21, 2016, 03:33:48 PM by ebag4 »
GO CARDS!!!
Offline drewh1
Reply #8 on: March 21, 2016, 03:28:32 PM
Solder joint near white wire middle of board looks suspect as well.
J-River on Custom built Music Server in Silverstone Case
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Diy Cotton wrapped wire interconnects and speaker cab!es
Green Mountain Audio EOS HDx speakers
Crack with Beyerdynamic T1
Shunyata Diamond Back Power Cable
DIY Sub with Seas L26Roy Driver
Offline HiFi Builder Guy
    • HiFi Builder Guy Facebook
Reply #9 on: March 21, 2016, 04:44:58 PM
It looks like you are missing the B side LM431.
Shawn
HiFi Builder Guy
Offline mpdd
Reply #10 on: March 21, 2016, 04:58:37 PM
You're absolutely right. I can't say how many times I've been through the directions piece by piece and stared at that board. The soldering iron is heating up as I write this. Thank you all for taking the time to look at this. I'll post results later. Thanks,
Michael
Offline mpdd
Reply #11 on: March 21, 2016, 05:53:19 PM
Thanks all, I got the missing LM 431 in that cleared up the voltage issue at OA but was still low at 26 U. I took the board off and touched up all the solder connections, after the resolder everything measures per specification. Thanks again to all of you for taking a look and helping out.
« Last Edit: March 21, 2016, 07:47:38 PM by mpdd »
