Stereomour assembly resistance check
kevin flynn · 5210
Offline kevin flynn
on: April 26, 2016, 06:18:47 PM
Hi All,
I have my Stereomour assembled :), and most of the resistances check ok except for the last 2 >:(, # 47 and 48.
They're designated with a "*", -usually indicating fluctuating cap resistance.  These leads however are transformer taps.. Anyhow, these read as "open" on my amp.
Seems like the surrounding wiring is ok, and as noted other voltages appear to check out.
Any suggestions welcome/appreciated.
K.
« Last Edit: April 26, 2016, 06:33:32 PM by kevin flynn »
Offline Sugar Man
    • The Last Honest Lawyer
Reply #1 on: April 27, 2016, 04:25:33 AM
Kevin,
Did you see heavycowboy's similar thread a little further down?
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
Offline kevin flynn
Reply #2 on: April 27, 2016, 04:51:00 AM
Ah, no.  Will do.
Merci,
K.
Reply #3 on: April 27, 2016, 06:43:38 AM
The "*" generally indicates that you won't see any kind of reliable, repeatable resistance measurement.  If you're not getting something close to 0 Ohms at these terminals, you don't need to worry too much about them.
Offline kevin flynn
Reply #4 on: April 28, 2016, 11:50:29 AM
Okay, reviewed that thread, and apparently Cowboy forged ahead with his voltage checks.
After checking all the connections associated with the a/c inlet and the trafo connections, seeing no anomalies, but still getting a steady, repeatable "0" ohms, I did the same.
Voltages  checked out, and amp fired up successfully.
Kevin
PS: - Blackplate, do I interpret your comment correctly that the readings at 47 / 48 should be anything BUT 0 ohms, with normal readings fluctuating above 0 ohms, and steady "0" being an indicator of a short to the chassis or other issue?  -Really would like to figure this out if possible.  - Thanks
Reply #5 on: April 28, 2016, 04:51:37 PM
0 is a zero, or a dead short.  Open will show something like "OL" on your meter.
Offline kevin flynn
Reply #6 on: April 29, 2016, 06:05:58 PM
Ok, then, what I'm seeing is not 0.
The reading I have is "OL".
K
