1.5 / 2A fuse
fritzthecat · 9339
Offline fritzthecat
  • Analog Chris - Fritzthecat
    • Lakeside Audio Association
on: June 09, 2016, 08:23:02 PM
I am just curious - I read quite a few times that there are some issues with the 1.5 A fuse BH delivers with the Kaiju Kit. So far I had no problems and am still using the 1.5A one - can someone tell me at which point otf the build the 1.5 was most likely to blow? I am just about to finish my first build now.
Chris
Sony 557ESD
Thorens TD 124 Mkll
Lenco L70 (PTP tuned)
Apple Mac Pro / Media Center 23
AN Kits L4 Preamp
AN Kits L4 DAC / MiniDSP
AN Kits L3 Phono / Bottlehead EROS
Bottlehead Kaijus for JBL 2402, JABO 75 (JBL 2445/Truextent), Orishorn 150 (JBL 2108)
Silvercore 833C for (Klipschorn/Crites)
Offline caffeinator
Reply #1 on: June 10, 2016, 03:17:07 AM
Hello,
I have just been through that and I think my experience sounds consistent with those of others.
After good readings and no problems on the first HV check, the fuse blew on testing with 300B's right after that, and then blew a second time.  I was able to find some 2A slo-blo fuses, and using those, things checked out fine and no more issues.  I'd have tried 1.5A, but those weren't readily available.
I think after finishing up and some break-in, I will switch back to the correct rating (1.5A fast-blow) and see what happens.  On future builds, I might try using the Variac to ramp up voltage instead.
Best of luck to you!
David
Offline fritzthecat
Reply #2 on: June 10, 2016, 05:26:25 AM
Hi David
thank you for your reply - I then guess my 1.5A fuse just still is alive as I always used the variac with the 300b tubes inserted -anyway tonite or tomorrow I'll find out when finally adjusting the hum balancing etc. I have to turn it on again. My heart is always pounding like crazy when I have to do testing or turn on something I just built - I hope Kaiju number 1 is not gonna blow in the end - so far I had no big problems. Just couldn't find time this week to get some speakers on my workbench and to be honest just was afraid of screwing everything up just in front of the finish line...;o)
Maybe a sip of whisky helps before I push the power button. Three days ago I just did the output transformer wiring - so we'll see...
Chris
Sony 557ESD
Thorens TD 124 Mkll
AN Kits L4 Preamp
Offline ebag4
  • Bottlehead and GR Research, Yeah Baby!
Reply #3 on: June 10, 2016, 07:44:21 AM
Hi Fritz, that is a nice looking build you have there.  My experience aligns with David's, my fuse blew just after adding the 300B's as I recall.  No issue with the 2A slo-blo.
Best,
Ed
GO CARDS!!!
Reply #4 on: June 10, 2016, 01:40:25 PM
That is a very nice build indeed...John
Offline fritzthecat
Reply #5 on: June 13, 2016, 08:43:14 PM
Hi altogether - perfectionism is my biggest pain in the a... and others hate me for that as I tend to expect the same from co-workers...;-)  But actually I just love what I am doing sooooo much and building tube electronics - especially hardwired is just a great hobby and I am already saving money for the next Bottlehead kit - a bee pre with lots of tuning parts - looking very much forward to that one. A great day to everybody and I like very much being in here - it is a great Forum to exchange experience an knowledge. If anyone once makes it to Switzerland you are welcome in my house...:-)
Chris
Sony 557ESD
Thorens TD 124 Mkll
AN Kits L4 Preamp
Offline fritzthecat
Reply #6 on: June 13, 2016, 08:50:50 PM
PS: does anyone know where to get choke covers for the ones used within the Kaiju and how to attach them? To me it looks like one would have to türemove the frame holding everything together? Ideally I'd like to get some copper covers like AN uses but as far as I was able to research they have nothing available that fits. Actually I'd like o pimp the optics a little - like within the lomited edition Kaiju and Bee Pre.... In one of my Firstwatt F5 I build an aluminium cage around the toroid transformer to avoid the last bit of hum
Chris
Sony 557ESD
Thorens TD 124 Mkll
AN Kits L4 Preamp
Reply #7 on: June 13, 2016, 11:09:24 PM
That is a very tidy build, i applaud your attention to detail :)
Reply #8 on: June 14, 2016, 07:35:28 AM
Yes, and if you do that, you will most likely ruin the choke in the process.  The covers are installed when the chokes are being manufactured, and then are squeezed and varnished into the channel frame.
Offline caffeinator
Reply #9 on: June 14, 2016, 08:37:54 AM
There are transformer (and choke) covers that are more like cans or boxes that simply conceal the things underneath.
Search on ebay for "transformer cover" and you'll get many, many results.  One challenge is the footprint around the Kaiju chokes isn't really compatible with the typical covers, which tend to be either circular or rectangular in section (viewed from atop the transformer/cover).  It might be easiest to fabricate a custom cover.
Good luck!
David
Reply #10 on: June 14, 2016, 10:07:55 AM
Be aware that the plate choke dissipates a bit more than 2 watts, and a tight enclosure will make it more difficult to dissipate that heat unless some allowance is made for air flow.
Offline fritzthecat
Reply #11 on: June 15, 2016, 08:37:54 AM
This is exactly what I thought - so it's better to forget about that and maybe build a aluminium chassis around the choke allowing some airflow to avoid any heat problems - as far as I know these chockes can get quite warm so it is better o think about "air condition" - already got something in mind I similarly did for my Firstwatt F5 transformers - let's see, I love building everything with my own hands - guess I'll come up with something. Mostly I got more solutions than problems...;o) Anyway, thank you for your reply - very helpful.
Chris
Chris
Sony 557ESD
Thorens TD 124 Mkll
AN Kits L4 Preamp
Offline fritzthecat
Reply #12 on: June 19, 2016, 02:20:54 AM
At the moment I am using the 2A fuse but the 1.5 A made it through all test procedures even with inserted tubes when using the variac. When just pushing the power button I decided to insert the 2A type as I am a bit afraid about damages when the fuse blows (though it blows to avoid exactly that). I'll try the 1.5 A type tonite when just turning the amp on - let's see what happens.
I have a question regarding fancy tuning fuses: In my other kits I am using furutech or Hifi-Tuning high end fuses and they really improve the sound. So my question: does anyone have experience using these sound improving fuses in bottlehead kits? I read that they might react different than the standard types - so what does "different" mean in this context - are they not protecting my amp as they should or as the standard fuses do? So far I never experienced any issues but how is it with Bottlehead Kaijus for example?
Input regarding this is very much apreciated...;o)
Chris
Sony 557ESD
Thorens TD 124 Mkll
AN Kits L4 Preamp
Offline fritzthecat
Reply #13 on: June 21, 2016, 06:06:49 AM
Hi there - just for the sake of it: 1.5A blew immediately when pushing the power on button...
Chris
Sony 557ESD
Thorens TD 124 Mkll
AN Kits L4 Preamp
