Troubleshooting -- LEDs Don't Light [resolved]
baby-alligators · 4523
Offline baby-alligators
on: August 08, 2016, 04:11:28 PM
Hi,
I have a problem with the LEDs in the chassis of the Bottlehead Crack. All of the resistance checks seem to be okay (with a little weirdness on 13, but googling returned results saying it was probably okay). When I plug it in, the LEDs inside do not light up. Both silver banded sides are facing in, and they are both new after having to order replacements.
Resistance checks are as follows:
Expected Actual
1  *
2  *
3  0 ohms
4  *
5  *
6  2.4K ohms
7  2.9K ohms
8  0 ohms
9  2.4K ohms
10  2.9K ohms
12  0 ohms
13  *will climb slowly towards 270K ohms
14  0 ohms
20  0 ohms
22  0 ohms
B3  2.9K ohms
B6  2.9 Kohms
RCA jacks:
Ground lug  0 ohms
Center pin  90-100Kohms
1  *
2  *
3  0
4  *
5  *
6  2.48K ohms
7  2.94K ohms
8  0
9  2.96K ohms
10  2.48K ohms
12  0
13  *drops from around 11-17M ohms or sometimes reads 0 ohms
14  0
20  0
22  0 *sometimes 0.1-0.4 ohms
B3  2.94
B6  2.96
RCA jacks:
Ground lug  0
Center pin  96.3, 99.3K ohms
Any help would be much appreciated. I can take pictures of any parts if that would be helpful.
Thank you for reading.
« Last Edit: August 24, 2016, 05:53:18 AM by Caucasian Blackplate »
Reply #1 on: August 12, 2016, 12:12:58 PM
Can you post any voltages in your Crack that aren't consistent with what's listed in the manual?
Reply #2 on: August 13, 2016, 12:58:25 PM
1: -.721
2: -.716
4: -.715
5: -.725
7: 4 mV
9: 5.2 mV
13: -.716
14: -233
15: -.705
20: -233
21: -.710
A1: -.723
A6: -.714
B1: -.720
B2: -.716
B3: 4 mV
B4: -.723
B5: -.715
B6: 5 mV
B7: .2 mV
That's all of the ones that are different than the listed voltages. Doesn't seem particularly "good." Thanks for the response and your help.
Reply #3 on: August 13, 2016, 03:52:39 PM
Do you have a fuse in the fuse holder?
Reply #4 on: August 17, 2016, 10:13:39 AM
Sorry for the delayed response, I was out of town and unable to confirm. Fuse has been in in the fuse holder during all testing, yes.
Reply #5 on: August 17, 2016, 10:29:13 AM
Are you sure that your power switch is not melted in such a way that the contacts aren't closing when switched on? The more or less all zero voltages are consistent with the power transformer not getting any juice. Do the tubes glow when you switch it on?
Reply #6 on: August 18, 2016, 10:03:15 AM
The power switch does not seem to be melted in any way. I can get pictures of any part though if you want them.
Both tubes glow when it is powered on.
Reply #7 on: August 18, 2016, 10:43:45 AM
Are you sure your meter is set properly and well connected to ground?
Reply #8 on: August 18, 2016, 04:19:58 PM
I'm pretty confident. I've been clipping the black lead to terminal 12.
Here's a picture of the meter and setting I've been using to test.
(https://i.imgur.com/g0FGZXK.jpg)
Offline fullheadofnothing
Reply #9 on: August 18, 2016, 05:45:56 PM
Post pictures of your build, especially the power supply.
Reply #10 on: August 19, 2016, 10:14:11 AM
Here's (https://imgur.com/a/4dVI5) an album with photos. Let me know if you need any pictures of other areas.
Reply #11 on: August 19, 2016, 10:53:34 AM
You are missing the wire connecting 12 to 14.
There are some other sketchy looking connections (the leads of the UF4007s on the transformer side are dangerously close to touching, some of your solder connections look like a wire poking through a blob of solder with no actual connection, the 9-pin looks problematic, but the shots of it are unclear).
Offline Deluk
Reply #12 on: August 20, 2016, 01:43:12 AM
Very brave not numbering up the chassis plate.
Reply #13 on: August 20, 2016, 06:46:41 AM
Ahhhh I'll check all those areas more closely and get that wire in. Thanks for taking a look. I think I forgot to reattach that wire when I was redoing some parts (back when I was troubleshooting not noticing the LEDs being the wrong way).
I appreciate you taking the time to respond!
Printed out the numbered page to have next to the build, but I definitely regretted not doing that a few times!
Reply #14 on: August 29, 2016, 03:13:22 PM
I did one check over the connections and added the wire, and got the LED going from the center of the 9-pin to A3 to light. The A8 LED is still not lighting.
While running voltage checks, I blew the fuse by accidentally short circuiting with the multimeter probe, so my troubleshooting has come to a stop until I get a new fuse.
