Hammond or Triad?
ALL212 · 5741
Offline ALL212
on: August 17, 2016, 03:58:27 AM
If using a choke is there a difference that should be noted that would determine which to use?
Triad C-7x vs. Hammond 158M.
Triad 90 DC m/a, 10 H, 270 ohm
Hammond 100 DC m/a, 10 H, 262 ohm
Hammonds are almost twice the price.
Aaron Luebke
Offline johnsonad
Reply #1 on: August 17, 2016, 09:02:55 AM
In my limited experience, neither transformer measures anywhere close to the listed value in resistance. I've both and the build quality or at least finishing is better for the Hammonds.  I noticed no difference when used as intended.
Offline Chris65
Reply #2 on: August 17, 2016, 12:29:03 PM
Triad is made in China, Hammond in Canada, which probably accounts for the price difference.
I also echo Aaron's comments.
Reply #3 on: August 17, 2016, 12:58:21 PM
I found the same as Johnsonad says when i had them side by side.  They are probably all made in China anyhow, as i found when i recently ordered a second Hammond power transformer.
Offline Chris65
Reply #4 on: August 17, 2016, 10:14:43 PM
Hammond source some small power transformers from China (like yours), but as far as I'm aware all Audio transformers/chokes are still made in Canada.
Reply #5 on: August 18, 2016, 07:40:14 AM
I have not bought a C7-X in a long time, but they have been built in several places over the years. When the Paramour first came out, they were built in Mexico and done the old-fashioned way, layer wound with paper between each layer - this reduces the stray capacitance, improving high frequency performance as a plate choke. At some point they switched to regular bobbins, and (IIRC) later they were clearly made by Hammond without attribution.
The C7-X comes up often, because it is widely available. But since the layer winding was abandoned, I know of no special reason to stick with it over others with similar specs.
Offline ALL212
Reply #6 on: August 18, 2016, 10:28:43 AM
I think in most cases we're replacing the 270 ohm 5w resistor.  How far off of 270 ohm can we be and still function according to spec?  These things are +- 20% IIRC.
Aaron Luebke
Reply #7 on: August 18, 2016, 01:33:05 PM
It's not very sensitive. At 70mA, a 270 ohm resistance will drop 20vDC, which is much less than the usual 300-400v in a power supply. I would not even bother to calculate it as long as the resistance is between 150 and 400 ohms.
Reply #9 on: August 19, 2016, 01:31:20 PM
Hah my pessimistic prediction was true, they are made in China now  ::)
Here are the two i have in stock,  Hammond 11.9H 192r, Triad 14.2H 244r
Offline ALL212
Reply #10 on: August 20, 2016, 01:46:27 AM
For the Hammond it gets worse...
Triad 10.2 H
Hammond 5.3 H
I'm wondering now if I have a mislabeled choke from Hammond?
I'm going to return it - or try, and see what happens with the next one.
« Last Edit: August 20, 2016, 01:49:56 AM by ALL212 »
Aaron Luebke
Reply #11 on: August 20, 2016, 07:31:55 AM
How are you measuring inductance? It is a function of the applied AC voltage, AC frequency, and  the DC current. You will usually get a small measurement if the applied AC voltage is small (<10v?) and/or the frequency is high (>120Hz).
Offline ALL212
Reply #12 on: August 20, 2016, 12:46:51 PM
I've got an LCR meter.  I'm assuming it works ok.
Aaron Luebke
Reply #13 on: August 20, 2016, 05:55:50 PM
That was my guess - these meters often use 1kHz tones at a fairly low voltage. Fine for air-core crossover coils, or for RF chokes, but not as relevant for power supply or plate-load inductors.
Offline ALL212
Reply #14 on: August 21, 2016, 02:35:11 AM
Paul - does that mean I shouldn't trust it for measuring the chokes?  It appears close on the Triad but way off on the Hammond.
Aaron Luebke
