Tubes are lit, but LEDS are not.
mooopig · 2592
Offline mooopig
on: December 31, 2016, 02:49:33 PM
This is my first build and all of the resistances have checked out, and the tubes are lighting, but the LEDs do not glow. In addition to the LEDs not glowing I am getting:
1: -1.3V
2: -1.3V
3:  0V
4: -1.3V
5: -1.3V
6: 0V
7: -.005V
8: 0V
9: 0V
10: 0V
Offline fullheadofnothing
Reply #1 on: December 31, 2016, 03:12:21 PM
Cap is backwards.
Offline mooopig
Reply #2 on: December 31, 2016, 06:20:15 PM
Sorry, do you know which one?
Cap is backwards.
Reply #3 on: December 31, 2016, 06:49:16 PM
RTFM.
Also your diode mounting is suspect, but harder to see.
Offline Alonzo
Reply #4 on: December 31, 2016, 08:47:04 PM
Hi,
Welcome to the forum.  Please go back and check the orientation of the capacitors, seems you have one backwards and any further actions may cause it to blow.  The manual has clear instructions on installing them, please look at the included pictures.
Also, check your positioning and soldering on the diodes.  Maybe practice soldering a few more times.
Attach some additional closeup pictures so we can help you out.
Happy New Year!!
Dammit, I'm half lit and I can be more polite than that to a newbie...I hate that acronym.
Alonzo
Offline diynewbie
Reply #5 on: January 01, 2017, 05:20:41 AM
The backwards capacitor is the one connected to U12/13 (capacitor closest to tube socket on the side with two capacitors).  The overlapping diode arrangement in the manual is to prevent the leads (to terminals 20 and 21 on each side) from contacting each other.  You picture looks like the inside leads may be in contact.  Also, it is not clear if there is contact between the A8 diode lead and the wire to A7.
Offline Adrian
Reply #6 on: January 01, 2017, 07:28:04 AM
RTFM.
RTFM....Really?
Adrian C.
Offline mooopig
Reply #7 on: January 01, 2017, 08:21:14 AM
Fixed the capacitor and all the voltages checked out! And the amp is working fine! Thank you all for taking the time to reply (:
One more thing though would it be okay to make my own wooden base but take away 1/2 an inch from the height?
or is the height of the frame set so the amp can get the proper amount of ventilation?
Offline Leland Hankins
Reply #8 on: January 01, 2017, 09:50:33 AM
Yes, just so their is enough depth for ventilation, I rarely use the bottlehead rubber feet on the base.  If you are going to build a new base I recommend using 1/8-3/16" hobby plywood around the inside of the base , 3/4-1" wide, 3/16-1/4" below the top.  I like the reset look, use glue and air driven nails.  For me it is easier than cutting the groove and allows one to round over the inside top edge of the base.
Lee Hankins
