Bottlehead Kits
Crack
Center pin resistance check getting 00.0 [resolved]
Kozic
1928
Kozic
Jr. Member
January 10, 2017, 07:14:48 AM
So all the other resistance checks are fine, but the last one the center pin. both led banded ends are going to the center and and facing up all the joints look and feel good. even the top inner volume pot looks good. Any advice?
Last Edit: January 10, 2017, 10:39:02 AM by Caucasian Blackplate
fullheadofnothing
Global Moderator
Hero Member
A noble spirit embiggens the smallest man
Re: Center pin resistance check getting 00.0
Reply #1 on:
January 10, 2017, 07:35:20 AM
Center pin of what?
Kozic
Jr. Member
Reply #2 on:
January 10, 2017, 07:50:38 AM
The 9 pin tube socket it was the only "center pin" in the manual.
fullheadofnothing
Global Moderator
Hero Member
Reply #3 on:
January 10, 2017, 07:54:14 AM
Center pin of 9-pin socket should be zero. It is
not
called out in the resistance check. Center pins of the RCA jacks
are
listed in the manual, and must be ~100K.
Kozic
Jr. Member
Reply #4 on:
January 10, 2017, 08:02:21 AM
Bah you and your knowledge....
All is good THANKS man.
Edit; I just rechecked my manual and the RCA jack center is referred to as the solder cup.
Last Edit: January 10, 2017, 10:28:58 AM by Kozic
Bottlehead Kits
Crack
