Crack & Speedball -Wrong resistance and Voltage readings
alesi · 6030
Offline alesi
Hi,
after 4 years in the box I "managed" to assemble the crack incl. speedball update.
The first attempt was also my first attempt in soldering so I expected some hick-ups. I got a bit overexcited and without the right resistence readings I plugged it in to test the voltage. Tube started glowing, but unfortunately there was also some smoke coming from the region T12-T14, not sure whether it was the capacitor or the wirebound resistor underneath. I realised the the powder coating might be the culprit, next to my soldering skills. I desoldered everything (!) and started from scratch. This time I dremelled all points that required ground (ground lug, T3, T8). Looking at the resistance and voltage readings I always measure a 0 for both resistance and voltage. So at least this seems to be OK now. But nearly all red cable point readings seem to be wrong. Maybe a component is fried?
To note: T15 seems to get really hot, I think the solder gets soft there when powered on.
Terminal - suggested - my reading
1 -   *    - 1
2 -   *    - 1
3 -   0       - 0
4 -   *    - 1
5 -   *    - 1
6 -   2.4K  - 2.2
7 -   2.9K  - 1
8 -   0        - 0
9 -   2.9K  -  1
10-    2.4K  - 2.7
12 -   0       -   0
13 -   * will climb slowly toward 270K ohms   1 (no movement here, stay 1)
14 -   0 - 0
20 -   0 - 0
22 -   0 - 0
B3 -   2.9K - 1
B6 -   2.9K - 1
RCA jacks:
Ground lug    0 ohms   - 0
Center pin    90K ohms—100K ohms   - 1001
Terminal Voltage (VDC unless otherwise specified)
1    75-90 -   51
2    170 - 61.1
3    0   - 0
4    170   - 60.1
5    75-90   - 49.8
6    0   - 0
7    100   - 46.2
8    0   - 0
9    100   - 43.9
10    0   - 0
11    0   - 0
12    0   - 0
13    170   - 60
14    0   - 0
15    185   - 115 (seems to very very hot)
20    0   - 0
21    206   - 170
A1    90   - 49
A2    0   - 0
A4    0   - 0
A5    0   - (did not test)
A6    90   - (did not test)
A7    0   - (did not test)
A9    0   - (did not test)
B1    90   - 50
B2    170   - 60
B3    100   - 45
B4    90   - 47
B5    170   - 58.5
B6    100   - 42.6
B7    0   - 0
B8    0   - 0
I attached a few pics, please let mewhich part is more helpful and I will take more pictures.
Really appreciate any help. I have some T1 and HD600 cans here that wait to be powered!
Many thanks for any hints!
Offline fullheadofnothing
Reply #1 on: February 05, 2017, 10:01:29 AM
Remove speedball.
Install resistors.
Test resistances.
Do not test voltages until resistance checks pass.
Offline alesi
Reply #2 on: February 05, 2017, 10:15:51 AM
Is there anyway to test or pinpoint the error without removing the speedball add-on? I do not have the resistors anymore.
btw: Only half of the LEDs are lighting upon the speedball boards, is this normal?
Offline alesi
Reply #3 on: February 07, 2017, 01:32:02 AM
OK,
managed to get the wirebound resistors and removed the speedball addon.
It looks all good and it actually runs for the very first time.
Readings below
Terminal Resistance
1    -   *    -   starting from 30
2   -   *    -   starting from 15
3     -   0 ohms    -   0
4     -   *    -   starting from 20
5     -   *    -   starting from 50
6     -   2.4K ohms    -   2.4
7     -   2.9K ohms    -   2.9
8     -   0 ohms    -   0
9     -   2.9K ohms    -   2.9
10     -   2.4K ohms    -   2.5
12     -   0 ohms    -   0
13     -   * will climb slowly toward 270K ohms    -   Slowly reaches 200 and then MM shows 1
14     -   0 ohms    -   0
20     -   0 ohms    -   0
22     -   0 ohms    -   0
B3     -   2.9K ohms    -   2.9
B6     -   2.9K ohms    -   2.9
RCA jacks:
Ground lug     -   0 ohms    -   0
Center pin     -   90K ohms—100K ohms    -   Red: 85.9 white:102.3
Voltage
1    -     75-90    -    86
2     -    170    -    168
3     -    0    -    0
4     -    170    -    168
5     -    75-90    -    85
6     -    0    -    0
7    -     100    -    108
8     -    0    -    0
9     -    100    -    107
10    -     0    -    0
11    -     0    -    0
12     -    0    -    0
13    -     170    -    167
14    -     0    -    0
15     -    185    -    185
20     -    0    -    0
21     -    206    -    209
A1    -     90    -    85
A2     -    0    -    0
A4    -     0    -    1
A5     -    0    -    0
A6     -    90    -    86
A7     -    0    -    0
A9     -    0    -    0
B1     -    90    -    84
B2     -    170    -    167
B3     -    100    -    110
B4    -     90    -    85
B5     -    170    -    168
B6     -    100    -    108
B7     -    0    -    0
B8     -    0    -    0
It seems that all values are now in the correct range I hope.
What would be the best way to troubleshoot the speedball add-on?
Reply #4 on: February 09, 2017, 07:37:14 AM
You should go back through the Speedball manual and carefully review how you've mounted the TIP50 transistors.
We have since updated the Speedball manual to include a lot of large, red text to highlight that the way one mounts a TIP50 transistor is extremely important, and not mounting it correctly can cause the exact issue you had.
Offline alesi
Reply #5 on: February 11, 2017, 07:11:45 AM
so I have assembled the speedball again, went step by step, re-soldered all points but unfortunately I get the same voltage readings again. The resistance is also off. I have the slight feeling that something is wrong with the two smaller boards. None of the LEDs are glowing. Especially on one small board the G terminal next to the 150k ohm resistor seems to be broken as it was really tough to solder. The solder just doesn't want to stick there. Looks like I burnt the ring.
Any help how I can debug the error would be greatly appreciated.
1      *
2    *
3    0
4    *
5    1
6    2.5
7    *
8    0
9    *
10    2.5
12    0
13    *
14    0
20    0
22    0
B3    *
B6    *
1   68
2    66
3    0
4    64
5    52
6    0
7   55
8    0
9    46
10   0
11   0
12    0
13   61
14   0
15    116
20
21    172
A1   49
A2    0
A4   0
A5    ?
A6
A7
A9
B1    50
B2    60
B3    45
B4   47
B5    58.5
B6    42.6
B7    0
B8    0
Reply #6 on: February 14, 2017, 11:39:37 AM
There are no resistance checks in the Speedball manual you are working with.
Remove the 6080, leave the 12AU7 in, then recheck the voltages at terminals 1, 2, 4, and 5.
Offline alesi
Reply #7 on: September 16, 2017, 08:00:29 AM
Thanks Paul,
Unfortunately I didn't have time for the last 6months, but now I have a free week where I finally want to finish it!
I have removed the 6080 and left only the 12AU7 as suggested.
I set the multimeter to 600
1 - 208
2 - 198
4 - 198
5 - 193
The picture below shows which LEDs are glowing when both tubes are installed. Not sure if this helps.
Reply #8 on: September 16, 2017, 08:11:47 AM
Would you unscrew the two small boards and flip them over, then post another pic?  Do the LED's on the 9 pin socket illuminate? (Please don't do anything to them or with them if they don't, it's more an indicator of a different problem)
You said the stock amp was working, did it pass all its voltage checks?
Can you tell me a bit about the solder you're using?  There seems to be an unusual amount of flux on the boards.
Offline Deluk
Reply #9 on: September 16, 2017, 08:34:26 AM
A side comment. The wires from the RCA's and the vol pot are twisted here and they should be braided. I believe they are braided to minimise noise and cross talk. Does it make much difference?
Offline alesi
Reply #10 on: September 16, 2017, 08:38:40 AM
Both LEDs on the 9pin luminate.
Voltage check passed on the stock amp. I still have the numbers
1 - 86
2 - 168
3 - 0
4 - 168
5 - 85
6 - 0
7 - 108
8 - 0
9 - 107
10 - 0
11 - 0
12 - 0
13 - 0
14 - 167
15 - 0
16 - 185
The solder says it is Multi-core solder (60% tin, 40% lead)
Also this is my first time soldering, plus I resoldered it a few times, which explains the massacre on the board.
The picture shows that I connected the black cable on G directly with the resistor on one board as the the ring on the board was destroyed by my soldering.
I marked it with X.  This is the board where the LED does glow however. Restistance seems to be OK as well.
Reply #11 on: September 16, 2017, 10:26:23 AM
If you have an adjustable soldering iron, turn it all the way up.  If you don't have an adjustable soldering iron, you need to leave it on your solder joints longer.
The issue I'm seeing here is a lot of cold solder joints that look like they either haven't been heated enough or have way too much solder in them (or both).  My suspicion is that you need to reheat all of the solder joints on all your PCB's.
Offline alesi
Reply #12 on: September 17, 2017, 08:02:58 AM
OK,
I resoldered all of the joints on all boards and spotted a mistake I made on the board where the LED wasn't working. the red wire wasn't attached to I but to O.
Now the LED is illuminating, btw. is it correct that just one LED per board should light up?
Both LEDs on the 9pin light up but are quite dimmed after a few seconds in.
Voltage readings, most of them 50% of what they should be
1-70-90->54
2-170->68
3-0->0
4-170->65
5-75-90->54
6-0->0
7-100->48
8-0>0
9-100->47
10-0->0
11-0>0
12-0->0
13-170->62
14-0->0
15-185->120
20-0->0
21-206->173
A1-90->51
A2-0->0
A4-0->0
A5-0->0
A6-90->50
A7-0->0
A9-0->0
B1-90->50
B2-170->60
B3-100->45
B4-90->50
B5-170->60
B6-100->45
B7-0->o
B8 -0->0
Reply #13 on: September 17, 2017, 08:19:14 AM
You put the 6080 back in I'm assuming?  Please pull it out and remeasure terminals 1, 2, 4, and 5.
Offline alesi
Reply #14 on: September 17, 2017, 08:23:27 AM
Apologies, so now after removing 6080
1 - 197
2 - 195
4 - 195
5 - 195
