New Pot for Quickie
brucef · 7847
Offline brucef
on: March 30, 2017, 12:02:54 PM
I have seen a few posts talking about upgrading the volume pot. Can I get some suggestions / links to tried and proven pots?? Thanks in advance.
Bruce F
Offline BNAL
Reply #1 on: March 30, 2017, 01:00:52 PM
brucef,
I have had good results with this eBay DACT.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline brucef
Reply #2 on: March 31, 2017, 02:13:27 AM
Thank you sir! Are the connections the same as the stock one?
Bruce F
Offline BNAL
Reply #3 on: March 31, 2017, 02:50:10 AM
Yes. It is a little smaller both in size and the solder connections. I used some 22ga teflon wire for the ground connection.
Brad Nalitt
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline brucef
Reply #4 on: April 12, 2017, 02:08:51 AM
What is the resistance value for the volume pot?? I need to specify when I order one.
Bruce F
Offline Leland Hankins
Reply #5 on: April 12, 2017, 04:24:47 AM
I have two quickie's.  The one that I call stock (not really) has two PEC mono pots 100K, the modified quickie had two Khozmo mono attenuators (were removed for another build) and now has a stereo Audio Note 100K, I really like this little pot.  In my opinion the Audio Note is an outstanding pot, I do not believe that unless you like the looks and have money to burn on the Khozmo or equal quality attenuator that their is very little difference in sound quality.
I try to use two mono pots or attenuators for balance control when possible.  I do not understand why one would use a stereo pot and a balance pot when two pots or attenuators accomplishes the same results.  Never did like the Alps pot, but since there is a new version with better solder lugs it is a good price choice, but not better than the PEC and not in the same league with the Audio Note, IMHO.
Sorry for the long post, taking a break from taxes.
Offline brucef
Reply #6 on: April 12, 2017, 11:59:11 AM
Thanks for the info!
Bruce F
Offline brucef
Reply #7 on: April 12, 2017, 12:06:09 PM
Leland, where did you buy the Audio Note?
Bruce F
Reply #8 on: April 12, 2017, 06:00:24 PM
Hificollective in England, very quick service.
« Last Edit: April 12, 2017, 06:02:25 PM by Leland Hankins »
Offline brucef
Reply #9 on: April 25, 2017, 12:58:27 AM
I picked up an Audio Note pot and want to get some direction on swapping it out with the stock pot. Are the solder lug connections the same on the  the Audio Note as the stock pot? In other words, do I solder the wires to the new pot exactly the same way they are on the old one?
Bruce F
Offline aragorn723
Reply #10 on: June 06, 2017, 04:33:27 PM
Try this link, there's a way to check the pot wiring with a voltmeter.
https://www.google.com/amp/m.wikihow.com/Wire-a-Potentiometer%3Famp%3D1
