After years of joy, can't get computer to recognize DAC
bernieclub · 11740
Offline bernieclub
After a routine reboot, I unplugged and replugged my DAC to reset audio, and a quick "couldn't load xmos driver" message popped up.   I rebooted several times, repluggged the power to no avail.    The device manager shows "device can not start code 10" message.    I attempted to reload the driver from the manual link, But Norton says it's not safe and deletes it!  Any ideas?
Bernie
Bernie Zitomer
Offline fullheadofnothing
Reply #1 on: May 08, 2017, 11:46:58 AM
What kind of computer?
Offline bernieclub
Reply #2 on: May 08, 2017, 12:46:22 PM
It's an older PC running Vista.    When I first got the DAC, it started right up and I've had no problems at all.
Bernie Zitomer
Offline bernieclub
Reply #3 on: May 08, 2017, 12:49:44 PM
I guess I should see if I can get it to work on another machine.    I'm reasonably sure it's not the dac.
Bernie Zitomer
Reply #4 on: May 08, 2017, 02:03:53 PM
Microsoft will update software without warning, so my guess is it installed something when you rebooted (assuming it's connected to the Internet).
Another machine is a good test, although if it's an update issue, it may have the same problem.
Also if your card has TOSLINK, that is less fussy.
Offline bernieclub
Reply #5 on: May 09, 2017, 03:01:21 PM
Update...fixed!    I think you are correct FHON, this started around the same time updates were taking place.    After removing everything and starting over, music is playing.   Thanks for the encouragement.
Bernie
Bernie Zitomer
Offline Deluk
Reply #6 on: May 10, 2017, 02:20:23 AM
Interesting. Microsoft stopped supporting from April 12th this year. Did you actually get their final update? There probably wasn't very much in it.
Offline bernieclub
Reply #7 on: May 10, 2017, 04:42:37 AM
I believe I did, and it wasn't much.    I don't know why it interfered with the XMOS driver.    Also, I had to allow the download through Norton, which tried to block it.     All is well now.
Bernie Zitomer
Reply #8 on: May 10, 2017, 06:08:42 AM
Microsoft recently rolled out native USB2 Audio support for Windows 10, which on my machine decided it wanted control of the Bottlehead DAC. All i had to do was remove and reinstall the XMOS driver to sort it out. I wasn't aware of that update being rolled out to older OS's, but i guess its possible.
Offline bernieclub
Reply #9 on: May 10, 2017, 07:23:51 AM
I'm probably due for a new computer within the year....is there any reason to use the XMOS driver instead of the native setup?
Bernie Zitomer
