Stereomour [resolved]
rockdrummer · 8359
Offline rockdrummer
on: May 21, 2017, 04:26:28 AM
Hi , so everything tested out okay on my freshly finished original stereomour , finally got to looking it up after it sat in place for the week on the rack.
I notice the 12at7 has a slight cloud-like look inside the top of the glass. Then I notice a very slight crack across a few pins in the bottom.  The tube warms but does not glow. There is a slight hum in both channels that isn't affected by volume changes. I will post the original test numbers later.
If the tube is bad, should I wait to get a new one before I do more voltage tests?
Ben
« Last Edit: June 20, 2017, 10:21:53 AM by Caucasian Blackplate »
Reply #1 on: May 21, 2017, 06:16:33 AM
Yes, that tube is broken and dead. Sounds like it may have been stressed when pushed into the socket.
Offline rockdrummer
Reply #2 on: May 21, 2017, 07:01:31 AM
Thanks for the info Doc. I'm anxious to get one and guitar center has groove tube 12at7 in stock. Anyone suggest not using one of those?
Ben
Reply #3 on: May 21, 2017, 07:03:28 AM
That should work.
Offline rockdrummer
Reply #4 on: May 21, 2017, 07:08:34 AM
Ok great. Will report back!
Offline rockdrummer
Reply #5 on: May 21, 2017, 10:28:04 AM
There we go! Super quiet, dynamic as all get-out. Lots of tweaking and messing with placement, then comparing to adding in the quickie. Now for lots of listening!
Thanks again Bottlehead.
Ben
