Subwoofer Connection
amritdesai · 9058
Offline amritdesai
on: August 15, 2017, 10:48:03 AM
I'm reaching out because I'm not entirely sure if it's possible to hook my subwoofer up to the Stereomour II. Does anyone have any recommendations as to how I can accomplish this? I purchased on a whim, a Zu Audio Undertone subwoofer maybe making a few incorrect assumptions about integrating it into my system. So far, I've managed to come up with a few options.
1. Utilizing speaker outputs for subwoofer
2. Second preamp output - is this possible?
3. Wiring signal from switch to 3rd (unused) RCA - not sure how to control volume
Any help would be appreciated.
Thank you.
Amrit
Zu Audio soul Mk II, w radian 475
Zu Mission Cables
Stereomour II, JJ 2a3 40
Clearaudio Concept Wood Ortofon Black
Eros Phono Pre
Schiit Bifrost DAC
Synergistic Research Black Fuses
Reply #1 on: August 15, 2017, 11:44:37 AM
Choice #1 will work; the risk is that the residual hum from the 2A3 AC filament power may be more audible. The DC filament supply kit will reduce that hum quite a bit - I don't remember the actual amount, but we did measure it.  :^)
Taking the output from between the driver and power sections is possible in theory, but it's a bit complicated and I am not aware of anyone having tried it.
https://bottlehead.com/product/dc-filament-supply-for-stereomourii-amplifier/
Offline amritdesai
Reply #2 on: August 15, 2017, 12:05:16 PM
Paul,
I just talked to the Zu guys and a speaker level connection is actually preferred. I have the DC filament upgrade already installed so hopefully there will be no audible hum.
Thank you for your response!
Amrit
Zu Mission Cables
Eros Phono Pre
Schiit Bifrost DAC
Offline rockdrummer
Reply #3 on: August 16, 2017, 04:12:54 AM
Hi, I have the original Stereomour. I ordered rca splitters from Blue Jeans Cable and split the preamp signal before the Stereomour. I run 4 12" servo subs and 2 servo amps and it is very quiet. However, I resigned to adjusting 3 volumes then since I don't have a nice preamp, like say a smash or beepree.
Ben
Reply #4 on: August 17, 2017, 05:48:19 AM
I run the speaker outs from my Stereomour II to a HP XO. I tap off the input side of the XO to a pair of powered subs. Works well, I only have to adjust sub level occasionally due to source material.
Offline amritdesai
Reply #5 on: August 25, 2017, 06:13:32 AM
Thanks guys. I'm having a lot of success with the speaker level connection - the timing seems spot on. I'm blown away the difference the Undertone sub makes - I just can't believe how much music I've been missing!
 ;D
Zu Mission Cables
Eros Phono Pre
Schiit Bifrost DAC
Offline d_composer
Reply #6 on: October 02, 2017, 04:23:12 AM
Hi -- forgive my ignorance, but what is a speaker level connection? How do you have your subwoofer connected to the stereomour II? Thanks!
Reply #7 on: October 02, 2017, 04:34:55 AM
Binding posts or spring clips that accept speaker wire.
Offline d_composer
Reply #8 on: October 02, 2017, 11:26:44 AM
Thanks for the reply! Are the pics in this article accurate for connecting a subwoofer to the stereomour II?
https://www.cnet.com/how-to/how-to-hook-up-a-subwoofer-to-a-stereo-system/
Reply #9 on: October 02, 2017, 12:01:25 PM
Yes.
Offline d_composer
Reply #10 on: October 02, 2017, 12:16:50 PM
Thanks again!
