First Kaiju: Slight hum and somewhat low volume
aPodz · 13425
Reply #30 on: December 14, 2017, 03:47:41 PM
Ok, so far that's a well balanced amp.  Now you should see somewhere between 4V and 8V when you measure AC voltage between the black and red post on each speaker output.
Offline aPodz
Reply #31 on: December 15, 2017, 01:17:45 PM
Ok, i’m getting ~6.2V in both channels with the trim pots fully open. Should I conclude the Kaiju is operating exactly as it should?
Reply #32 on: December 15, 2017, 01:41:14 PM
It all sounds about right. Try a preamp if you have one.
Offline aPodz
Reply #33 on: December 16, 2017, 04:15:18 AM
Ok, I'll give the preamp a try!
I realize this might not be the best thread to discuss the topic, but what would be the pros and cons of the Smash vs the Bee? I realize that you recommend the Bee as a great pairing for the Kaiju, but if I don't have $1200 burning a hole in my pocket, what would be the drawbacks of the more cost conscientious choice of the Smash?
Reply #34 on: December 16, 2017, 06:13:58 AM
The BeePre has more resolution and of course it has the 300B body and weight. With the upgrades the Smash has a similar Bottlehead house sound, just a little bit less refined. It's always surprising to me to listen to a Quickie, Smash and BeePre in sequence. They are different, but since they are all DHT the differences are not as extreme as one might assume.
Now the Neothoriator as a preamp, that's a whole 'nother level.
