Wiring replacement pot (Alps)
Rossputin · 14127
Reply #45 on: November 25, 2019, 09:34:14 AM
It could have something to do with the wire leaving the pot and going to A7.  I see way too much jacket stripped off on the A7 end, and if that bare section touches other connections, then you'll lose the channel.
Offline ryburdman
Reply #46 on: November 25, 2019, 11:02:44 AM
I didn't mess with the connection at a7 at all in the switch. I just inspected it and it's not touching anywhere. That said I can make a new wire for that and solder it on to make absolutely sure. Any other ideas on what might make me lose the channel.
Ryan Burdick
Reduction/Crack/Aune X1s/RebelAmp/6xx/Mangrid Tea/Tin t2
Reply #47 on: November 25, 2019, 01:26:37 PM
That wire had to move to change the pots out.  It is literally connected to the pot!
I would perform another voltage check to be 100% certain.
Beyond that, you can temporarily solder in a little jumper wire between A2 and A7.  That will sum the outputs of the pot and could provide some useful information.  If you happen to lose both channels when you do that, be sure to rotate the volume control through its entire rotation to see if things come back in part of the rotation.
Offline ryburdman
Reply #48 on: November 26, 2019, 03:58:44 AM
New wire to A7 and a bit of fiddling fixed it. Thanks!
Ryan Burdick
