Noise with Computers, USB DACs, and Powerline Ethernet Kits
Paul Birkeland · 481952
Reply #105 on: March 29, 2021, 06:39:57 PM
That works for noise control, but is not as safe as it should be. The chassis plate and transformer cores should be bonded to the safety ground with no interruptions; the ground lift should occur between the signal ground and chassis; i.e. at terminal 28.
That's a pretty inconvenient location, unfortunately - a great many wires go to that terminal. It will be tricky!
Offline sl-15
Reply #106 on: March 30, 2021, 05:44:00 AM
Thank you Paul, indeed terminal 28 would be tricky. PB said on the first page of this thread:
I don't see issues doing this with any of our products.  I do also plan to test whether a UF4007 can throw a 20A breaker and survive, as this could also be a suitable part to use.
If you are saying that this mod is not the safest for the Foreplay then I would consider reversing it, it's nice without the noise but I rather would go the safe route.
Could you or PB confirm the safety of this mod? Thanks, Best, Stefan
Stefan Hampel
Reply #107 on: March 30, 2021, 05:54:17 AM
This is a workaround for older kits.  For new kits, we separate the audio ground and the chassis plate with the antiphase diode arrangement plus some other parts, and this is the safest choice.  For our older kits that are not designed from the start to have these parts, the solutions are less than ideal. It would take a very catastrophic failure (like say replacing the power cord on your electric clothes dryer with the power cord plugged into the wall, then dropping the bare end of the power cord onto your Foreplay's chassis plate) to cause problems with the diodes installed, but it is remotely possible.
Offline Tomunizum
Reply #108 on: April 12, 2021, 10:53:58 PM
Hello,
Just finished my stock Crack build and I’ve discovered through process of elimination that my crack produced a static noise whenever my FIIO K5 Pro external DAC/amp’s USB is connected to my desktop computer. The static increases in volume when the volume on the crack is increased but not when the DAC/amp’s volume is increased.
I’m pretty confident that my solder joints are good, as tapping on the unit produces no distortion or anything audible.
I’m wondering if using an optical connection would resolve the issue.
I would greatly appreciate any advice or help anyone is able to offer regarding this issue.
Thanks I’m advance.
Tom
Reply #109 on: April 13, 2021, 05:33:58 AM
An optical connection will resolve the issue, or there's this:
Offline Tomunizum
Reply #110 on: April 13, 2021, 05:49:38 AM
Aha!
I had read that thread as it sounded similar and wondered, but did not want to assume.
I think I will move forward with adding a ground breaker, thank you much!
Would you mind explaining why this is happening and how this fixes it? I found it interesting because whenever I moved my computer mouse I could cause a noise in addition to the background static.
Tom
Reply #111 on: April 13, 2021, 07:18:31 AM
The diodes create some separation between the Crack earth and the earth of the computer, which will interrupt the flow of low level noise that would otherwise be there.
Offline Tomunizum
Reply #112 on: April 13, 2021, 04:34:48 PM
Okay gotcha. Was trying to read a bit about the anti parallel diodes.
Thanks a bunch Paul!
Tom
Offline vaplen
Reply #113 on: June 15, 2021, 01:28:00 PM
I want to try this on my SEX kit.  I also have USB noise on my odac.
I drew a picture of what I think needs to be done.  So basically I solder the twisted diodes at the red points and the black line represents the twisted diodes. Anything I am missing?
Also currently looking at the 1n4007 for this mod.  Anyone have a better recommendation?  I guess the ones Paul mentioned are all good for this.
Does this look correct?
Reply #114 on: June 15, 2021, 02:34:16 PM
1N4007 will do the job.  The little piece of bus wire going from the solder lug on the chassis up to the IEC power entry module needs to be removed in the process as well, as the diodes are taking its place.
Offline vaplen
Reply #115 on: June 17, 2021, 09:21:22 AM
Thanks Paul, if I understand correctly just the single piece of bus wire going up to the IEC power entry module should be removed.
The 2 other pieces of bus wire should remain, correct?
Also should I reverse the polarity of the diodes like in your original picture?
Much appreciated.
Reply #116 on: June 17, 2021, 09:29:35 AM
Yes, the piece of bus wire wire going to the earth lug on the IEC power entry module is removed and replaced by the pair of diodes.  The diodes need to be wired antiphase.
Offline Drew1d
  • Guitar amp hobbyist
Reply #117 on: March 28, 2022, 07:42:40 AM
Totally needed for me.  Also worked like a charm!!!
Like, static, that changes pitch depending on the screen.  Pulled the RCA, and dead quiet, so I knew the noise was after the Crack.  And now....holy flippin' motherlovin' cow!!!  It made my HD650s come to life!!!
Drew Peterson from Westchester
Offline rguenther
Reply #118 on: May 12, 2022, 12:51:15 PM
Hi there,
I've been reading this thread (and others) and didn't find my situation covered.
My Crack + Speedball produces crackling/noise on the left channel. Only power and headphones are plugged in, nothing on the RCA jacks. Turning the volume pot doesn't affect this.
All joints seem fine, poking around and re-heating many didn't make a difference.
What I've observed: my laptop (and monitor etc) are sitting right beside the Crack.
a) unplugging the laptop (and all other devices in this room) from power doesn't affect the crackling
b) unplugging the laptop AND moving it 4-5meter away: the crackling stops
Could this be solved through the suggested diode mod as well?
Reply #119 on: May 12, 2022, 01:03:56 PM
You may be picking up pollution through the air.  Does the noise go away if your laptop is running on batteries?
