Possible Channel Imbalance[Solved]
XforceVesa2 · 51293
Offline XforceVesa2
Reply #60 on: February 08, 2020, 08:27:07 AM
You're the only one...
I did leave space in the layout to add feedback resistors, which would tighten up the channel balance.
Ok..(I thought that some Imbalance is normal on this Amp(So I have misunderstood this))  :/
If I want to add feedback resistors in this circuit where must they placed?
Before I consider to add feedback resistors in this circuit, should I resolder the solder joints from the Input Tube Socket and from the High Current PC Boards?
« Last Edit: February 08, 2020, 08:28:41 AM by XforceVesa2 »
PC/Hackintosh with Roon -> RME ADI-2 DAC(Cinch LineOut: Ref Level: +7dBu @ 0.0dB) -> Bottlehead Crackatwoa AMP -> Sennheiser HD 600
Reply #61 on: February 08, 2020, 08:29:19 AM
No, I meant that most builders wouldn't be bothered by half a dB of imbalance.
Offline XforceVesa2
Reply #62 on: February 08, 2020, 08:37:37 AM
Ok... now I got it.
As this is no real issue, this thread can be seen as Solved and I want to apologize for my nitpicking with the Channel Balance as I'm just waste your and my Time, to fix an Issue what's not an real issue.(As I have tested it for myself that I shouldn't be able to hear this Imbalance).
« Last Edit: February 08, 2020, 08:50:39 AM by XforceVesa2 »
