C4S LED and voltage issue
Loquah · 10426
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
Reply #30 on: May 12, 2020, 09:12:54 PM
OK, so the OB voltage that really wanted to spend the rest of its life at 6V has popped back up without the regulator in the way.
I believe your issue will be resolved by replacing the 431 regulator on the offending channel, with the slightest possibility that you'll also need a 12AU7.
Thanks Paul - I appreciate your help and patience. I've ordered the required parts and will advise once installed
« Last Edit: May 12, 2020, 11:30:14 PM by Loquah »
Offline Loquah
    • Passion For Sound
Reply #31 on: May 14, 2020, 10:23:39 PM
I've replaced the TL431 and swapped in a fresh 12AU7. All voltages are correct EXCEPT Kreg (B side) is still reading only 6V.
All tubes are new compared to when original issue arose.
Reply #32 on: May 15, 2020, 05:22:27 AM
Are you able to adjust the bias per the instructions in the manual?
Offline Loquah
    • Passion For Sound
Reply #33 on: May 15, 2020, 03:22:41 PM
Yes! I think the A-side trim pot was out of range if there's such a thing. A few extra turns and I'm back in range.
Thanks so much, Paul. Can I ask one more question?
Should I be wary of trying any of the previous tubes back in the amp? If the tubes have failed could they cause problems if I reinsert them?
Offline diynewbie
Reply #34 on: May 16, 2020, 01:15:57 AM
Good question, looking forward to Paul's reply.  I would suggest that you download data sheets and use your meter to check for shorts.
Reply #35 on: May 16, 2020, 04:43:38 AM
The amp should tolerated shorted 6C45PI tubes pretty well.  Things will heat up if you leave them in there running for a long time though.
Offline Loquah
    • Passion For Sound
Reply #36 on: May 16, 2020, 03:25:11 PM
Thanks, Paul. I'll fire it up quickly, check for sound (with sacrificial test headphones) and respond accordingly
