Bottlehead Kits
Kaiju Stereo 300B amp
DC Filament Question [resolved]
Jameson
4818
Jameson
Intern in Chief
Administrator
Sr. Member
May 15, 2020, 01:53:24 PM
Is 5.6V ok to get on the 300Bs during the test? I assume so but it is outside of the range but a little over 10% so thought I’d ask
Last Edit: May 16, 2020, 09:27:59 AM by Paul Birkeland
Jameson O'Guinn
Managing Partner
Paul Birkeland
Global Moderator
Hero Member
Re: DC Filament Question
Reply #1 on:
May 16, 2020, 04:41:48 AM
This is 5.6V at pins 1/4 on the socket itself? Are you using the 0.51 ohm resistors? Pics of the install?
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #2 on:
May 16, 2020, 04:47:46 AM
It is on pins 1/4 on both the A and C side. I’ll post pictures in a bit. I don’t have the instructions in front of me, but I did use all available resistors from the kit.
Jameson O'Guinn
Managing Partner
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
May 16, 2020, 05:02:12 AM
Also, does your meter have a 20V range? On a DC range like 600V, seeing 5.6V wouldn't be that surprising.
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #4 on:
May 16, 2020, 05:05:32 AM
It auto ranges. Should I try to force it into the 20V range?
Jameson O'Guinn
Managing Partner
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
May 16, 2020, 05:08:07 AM
No, any autoranging meter should resolve 5V just fine. What voltage do you get on the terminal strips where the DC output of the regulator board lands?
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #6 on:
May 16, 2020, 05:21:25 AM
B tube
Jameson O'Guinn
Managing Partner
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #7 on:
May 16, 2020, 05:21:57 AM
C tube
Jameson O'Guinn
Managing Partner
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #8 on:
May 16, 2020, 05:22:53 AM
DC board
Jameson O'Guinn
Managing Partner
Paul Birkeland
Global Moderator
Hero Member
Reply #9 on:
May 16, 2020, 05:26:26 AM
You have not properly installed the board.
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #10 on:
May 16, 2020, 05:31:28 AM
You know, I went over those instructions about a thousand times and still managed to get that final step wrong.
Please forget this happened. I won’t, but you can.
Jameson O'Guinn
Managing Partner
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #11 on:
May 16, 2020, 05:33:54 AM
For whatever reason AC In and DC out made a bunch of sense. AND I only had one IPA while doing it. Embarrassing.
Jameson O'Guinn
Managing Partner
Paul Birkeland
Global Moderator
Hero Member
Reply #12 on:
May 16, 2020, 06:11:59 AM
I mean, if you've put that same board into a Stereomour, I could easily see how this would happen.
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #13 on:
May 16, 2020, 06:28:53 AM
Hokay. With the error fixed I’m within the right range on both tubes. I’ll let the caps discharge and go do some chores then see how it sounds.
Thanks for the eagle eye, as always
Jameson O'Guinn
Managing Partner
Jameson
Intern in Chief
Administrator
Sr. Member
Reply #14 on:
May 16, 2020, 07:09:11 AM
Hot damn, that works really nicely. By far the most noticeable upgrade I’ve done.
Jameson O'Guinn
Managing Partner
Bottlehead Kits
