S.E.X. amp seconde hand
mwgrient · 15508
Offline mwgrient
on: May 22, 2020, 06:46:21 AM
Dear all,
I have a Bottlehead S.E.X. amp. Bought second hand, hence I am not feeling comfortable yet to build a complete system like the S.E.X. amp.
When I attache the power cable (220v) there is a loud sound from the headphone: It sounds "like a dolphin". I instantly shut down the amp of course.
My question is: does someone recognise my description of the sound (dolphin)? And maybe knows where to start. Could It be the tubes are dead?
Regards, hope that someone can help me a little bit further...
Marco   :)
Reply #1 on: May 22, 2020, 06:49:22 AM
Does it have a 240V transformer or is it wired for 240V?
If you don't know, you can flip it over and post pictures of the bottom of the power transformer.
Offline mwgrient
Reply #2 on: May 22, 2020, 07:05:07 AM
Hi, hope you can see the attachments for this!
Reply #3 on: May 22, 2020, 07:10:13 AM
Alright, so you have a 240V SEX amp, are you in a 240V country?
This noise could easily be external interference from a wireless device like a router or a cell phone, or a badly polluted powerline.
There's maybe a 0.1% chance that it's tube related.
Reply #4 on: May 22, 2020, 07:12:42 AM
The sound you describe is an oscillation. Most likely it is due to dirty tube pins or a bad connection somewhere. Try cleaning the tube pins and sockets for starters.
Offline mwgrient
Reply #5 on: May 22, 2020, 07:17:16 AM
oscillation: OK, I will clean the tubes! They are dirty in deed.
country: I am in a 220/230 country (Europe/The Netherlands) I have bought the amp in Norway (240). And I also will eliminate interference.
Offline mwgrient
Reply #6 on: May 22, 2020, 07:26:48 AM
Cleaned the tubes, no effect. After some seconds (with the volume closed) there is my loud oscillation sound.
Reply #7 on: May 22, 2020, 07:44:03 AM
Is the sound only in one channel? If you wiggle the tube can you get the sound to stop?
Offline mwgrient
Reply #8 on: May 22, 2020, 07:55:09 AM
one side only! If I touch the right (this must be left) tube (having the amp in front of me), and touching the tube, the sound changes a little bit. But keeps on going loud... wiggle the tube does not effect it.
I also found that if I turn up the volume a bit, It goes away?
« Last Edit: May 22, 2020, 08:43:46 AM by mwgrient »
Reply #9 on: May 22, 2020, 08:43:22 AM
Now swap the tubes in the sockets and see if the noise follows the tube.
Offline mwgrient
Reply #10 on: May 22, 2020, 08:45:23 AM
it does not, stays left channel: so it is not the tube!
Reply #11 on: May 22, 2020, 09:16:32 AM
Then it is possibly a bad solder joint. A good place to start would be to reflow the solder joints around the tube socket on the noisy side.
Offline mwgrient
Reply #12 on: May 22, 2020, 09:34:17 AM
Gould it be the potentiometer/volume? I have oscillation when I turn off the volume, then when I turn it on, It goes away. But on 12 a clock the oscillation is loud again. Etc.
Reply #13 on: May 22, 2020, 10:05:30 AM
If you have nothing plugged into the inputs of the amplifier, then noise that varies with the position of the potentiometer isn't useful information.  Your amp is just picking up ambient noise at the inputs and you're controlling how much gets into the amp by turning up the volume pot.
Offline mwgrient
Reply #14 on: May 22, 2020, 10:20:39 AM
OK, thanks for the information! I have nothing in the input.
I have re-soldered every joint on both tube sockets, but no effect at all. Pitty. And did a good look at all the soldering joints. Not luck either.
