Bad voltage at C4S board
kjwcb2 · 4123
Offline kjwcb2
on: June 14, 2020, 06:49:06 AM
Hi! I have a reading of 124.9DCV at 1A on the C4S board. 1B is fine at 220.2VDC.
Any clue what might be causing this? Presumably an issue with the shunt regulator board.
Reply #1 on: June 14, 2020, 07:00:57 AM
Is this an Eros 1 or Eros 2?  Is this the board above the D socket?
Offline kjwcb2
Reply #2 on: June 14, 2020, 09:28:53 AM
It's an Eros 2. Yes, it's above the D scoket.
Reply #3 on: June 14, 2020, 10:28:56 AM
IA and IB are wired together with a piece of wire.
Either your piece of wire is broken, or it isn't connected between those terminals.
Offline kjwcb2
Reply #4 on: June 14, 2020, 10:56:05 AM
I've got the jumper between 1A and 1B. It seems to be fine, but I'll replace it anyway and see what happens.
Reply #5 on: June 14, 2020, 01:57:20 PM
You can't have a wire between IA and IB and have a difference in voltage of 100+ V.  The wire has to be broken, out of place, or poorly soldered.
Offline kjwcb2
Reply #6 on: June 21, 2020, 05:31:58 AM
Hi, I replaced the wire between 1A and 1B. No real difference. The readings now are: 1A - 148VDC / 1B - 214VDC. A 65VDC difference +/-
Interestingly, the reading at the MJE5731A transistor next to 1A is 219.8VDC, compared with 152VDC at the MJE5731A next to 1B.
Reply #7 on: June 21, 2020, 05:56:51 AM
You can't have a difference in voltage between IA and IB with a piece of wire connected.  This is a physical impossibility.  100V across a piece of wire like that would dissipate thousands of watts and the copper would evaporate and possibly explode loudly in the process (though the power transformer wouldn't support this).
Offline kjwcb2
Reply #8 on: June 21, 2020, 07:06:31 AM
What photos would you like?
Reply #9 on: June 21, 2020, 07:10:09 AM
The top and bottom of the C4S board above the D socket.
Offline kjwcb2
Reply #10 on: June 21, 2020, 07:45:18 AM
Here they are.
Offline kjwcb2
Reply #11 on: June 21, 2020, 08:04:02 AM
Are they clear enough? I removed the heatsinks to test the transistor voltages. The board is a bit messy in places from all the soldering and desoldering.
Reply #12 on: June 21, 2020, 09:30:42 AM
What type of solder are you using, what wattage is your soldering iron (is it adjustable), and are you using any additional flux or anything?
What DC resistance do you get between OA and OB with your meter?
Offline kjwcb2
Reply #13 on: June 21, 2020, 09:46:25 AM
I'm using the best solder I can find locally. I don't think it's anything special but I've made 3-4 amp builds with it without any problem. I've got a Hakko soldering station - adjustable - set at 250 degrees.
The resistance between OA and OB is 441.4 KΩ. DC = 0.
Offline kjwcb2
Reply #14 on: June 21, 2020, 09:49:21 AM
That's with the board disconnected.
Sorry for spoiling your Sunday!
