(I think) blown capacitor on new crack build [resolved]
rat3hat · 7786
Offline rat3hat
Reply #30 on: July 11, 2020, 11:20:55 PM
There was a poor solder joint at the bottom left-most (closest to the 9-pin socket) point of the headphone jack. There are 2 black wires connected to it and a repeat of the "pencil test" with a bit more vigour revealed consistent crackling when either black wire was touched.
I have plugged in proper headphones finally.
I'll use it for a bit, then swap some tubes, then put in the Speedball in a few weeks.
Thank you again for your help. It has been humbling and rewarding.
Best,
Chris
Offline Deluk
Reply #31 on: July 12, 2020, 01:54:02 AM
Don't forget to replace the led.
Offline rat3hat
Reply #32 on: July 12, 2020, 04:13:27 AM
Thanks for the reminder. I absolutely would have forgotten to do that. I've just ordered a replacement pack from the Bottlehead shop.  Is it safe to use the amp normally before this is replaced? If not a safety issue, is there a quality issue?
What electrical function does the LED serve? Does it drop the voltage slightly or something along those lines?
Thanks again.
Offline Natural Sound
Reply #33 on: July 12, 2020, 05:16:27 AM
Thanks again.
Wait until you get your replacement LED's. Their function is to bias the cathode on the 12AU7.
Offline rat3hat
Reply #34 on: July 12, 2020, 05:45:50 AM
Thank you.
Reply #35 on: July 12, 2020, 09:54:06 AM
The amp is 100% safe and fine to use with one LED if you have the jumper between A3 and A8.
