(I think) blown capacitor on new crack build [resolved]
rat3hat · 7857
Reply #15 on: June 27, 2020, 08:19:39 AM
You aren't heating the joints enough.  Look at 19 and 18 lower terminals.  Do you see how there's no solder flowing through the terminal strip?  Now hold your iron onto each of those terminals until the solder flows into the terminal strip, then repeat for the whole amp.
Offline rat3hat
Reply #16 on: June 27, 2020, 08:25:11 AM
Thank you Paul. On it.
Offline rat3hat
Reply #17 on: June 29, 2020, 07:38:50 AM
Thank you, again for your help. I feel like a 3 year old. Humbling!
Another round of re-soldering. My current voltage checks fail for terminals 1 & 7 now.
1 is supposed to be 50-100V, it is reading ~158V
7 is supposed to be 90-115V, it is reading ~155V
What have I done?!
Tx
Reply #18 on: June 29, 2020, 08:24:47 AM
Do both halves of your 12AU7 glow?
Offline rat3hat
Reply #19 on: June 29, 2020, 09:04:26 AM
It looks like it. Photo attached.
Reply #20 on: June 29, 2020, 09:18:34 AM
Can you carefully measure the voltage at A8?
Offline rat3hat
Reply #21 on: June 29, 2020, 09:55:08 AM
1.63V
Reply #22 on: June 29, 2020, 10:01:56 AM
How about A7?
Offline rat3hat
Reply #23 on: June 29, 2020, 10:52:11 AM
Small spark when measuring at A7. A7=0V.
Remeasuring A8, it is now 13.3! I checked it several times, this time, and last time.
Reply #24 on: June 29, 2020, 11:07:30 AM
And the LED is not lit?
That LED is toast.  You can temporarily place a wire between A3 and A8 to get around this issue.
Offline rat3hat
Reply #25 on: July 01, 2020, 07:42:34 AM
Thank you, Paul. I really, really appreciate your help.
That LED did go (i.e.; it no longer glows) and a wire from A3-A8 did get the voltage at A8 back to 1.6. The other voltage measurements in the manual are back to matching the ranges. Earlier in this thread 1 and 7 which were (I think) erroneous are now in range.
A7 = 0, is that correct? I have assumed it is.
The amp turns on and the tubes glow. The other LED glows. When I 1st turned it on, it had more low grade background noise, which didn't change with the volume knob. It produces sound. The amp still has pops and clicks, some loud. I assume this is my apparently abysmal soldering! Would you perhaps advise an overhaul level, desolder/remove some solder, re-solder to sure everything up? Humbling!
Tx
Reply #26 on: July 01, 2020, 07:46:28 AM
Pops and clicks could certainly be solder joint issues.  One thing we will recommend is to plug an inexpensive pair of headphones into the amp and poke around the circuit with a wooden chopstick to see which joints set off the noises.
Offline rat3hat
Reply #27 on: July 05, 2020, 07:08:13 AM
Hi
I have done the chopstick test, and patched that wire past the dead LED. I can't really get it to crackle by touching anything. Today I turned it on, let it warm up for 30 mins or so, then plugged in a DAC and sacrificial headphones. For maybe 5 minutes, sounded noise free. Then, there was a loud crackle/pop. I took the headphones off my head (it was loud). I don't quite understand why, but the music player stopped. Laptop> USB> DAC> RCA> Crack. When I pressed play again, it played OK.
I have a few times been over the soldering and can't really find an issue. Frustrating. I am guessing it is still likely a soldering issue somewhere?
Thanks again for the hand-holding.
Reply #28 on: July 05, 2020, 07:15:17 AM
If the music player stopped, it's possible that what's going on may not be in the Crack itself.
Offline rat3hat
Reply #29 on: July 05, 2020, 07:32:55 AM
I do think it is very, very odd.  The same setup has always worked without issue (same laptop>DAC>[amp]>headphones) with at least 2 other amps. I will go and try it with another amp again now.
