voltage discrepancy OA/OB
denti alligator · 4636
Offline denti alligator
on: June 28, 2020, 05:23:05 AM
Finished my build, which went fine. All checks out OK, except for a discrepancy in voltage on OA and OB.
OA measures 169, which is on target. OB measures 141.
I reflowed the join and ones directly connected. I switched tubes. No difference. Sound is poor in left channel.
How should I troubleshoot this? Thanks for help in advance.
« Last Edit: June 29, 2020, 05:45:08 AM by denti alligator »
- Sam
Reply #1 on: June 28, 2020, 06:38:19 AM
Is this an Eros 1 or 2?  Is this OA/OB on the board above the D socket? Or the boards up front? (Eros 1 or 2???)
Reply #2 on: June 28, 2020, 08:16:41 AM
Sorry. Eros 2.
The OA/OB are on the C4S board above the C socket.
Note: all other checks were on target. In the meantime I've reflowed OB and C6 and 25 U and L. (plus almost all joints on the B side)
If it's any help, the LED closest to the top right corner of the board is glowing only faintly.
« Last Edit: June 28, 2020, 10:30:52 AM by denti alligator »
- Sam
Reply #3 on: June 28, 2020, 10:43:12 AM
Can you post some photos of the top and bottom of the C4S board above the C socket? If you have one LED on that board that doesn't glow like the others, this is 99% a solder joint issue.
Reply #4 on: June 28, 2020, 10:49:24 AM
Photos coming soon. It looks like all 4 on that side are glowing slightly less. Where do I start looking for a bad joint? Or should I reflow everything on the board first?
« Last Edit: June 28, 2020, 10:51:56 AM by denti alligator »
- Sam
Reply #5 on: June 28, 2020, 11:03:25 AM
Reflowed everything on the board's B side. That one LED isn't glowing. Could it be bad?
- Sam
Reply #6 on: June 28, 2020, 11:12:54 AM
You can measure the LED with your meter on the LED setting while it's installed on the board.  It should show 1.57V checked in one direction and nothing in the other.
Your images are 640x480, which is too small to really look at and get much of an idea about what's going on.  Is it possible to upload something with more pixels?
Reply #7 on: June 28, 2020, 11:30:16 AM
Here are some bigger pics. I have an extra LED so I can install that now.
- Sam
Reply #8 on: June 28, 2020, 11:54:11 AM
Sure enough! It was the LED. I put another one in and all checks out. Spinning tunes now.
- Sam
Reply #9 on: June 28, 2020, 12:10:58 PM
Dammit. Right channel dominates and left channel is too quiet. Balance is set right (on the main amp--Stereomour II--I double checked).
I tested this with a mono LP to be sure. What could be causing this?
Voltage discrepancy (though still within range) is now at
OkC  1.08
OkD  1.25
These are on the C4S board.
« Last Edit: June 28, 2020, 04:34:20 PM by denti alligator »
- Sam
Reply #10 on: June 29, 2020, 03:05:24 AM
Next morning... the amp sounds pretty bad, with the right channel dominating over the left.
Resistance readings are all on target.
Here are voltages for the C4S board:
IA: 216.4
IB: 215.7
OA: 168.2
OB: 164.4
OC: 98.8
OD: 99
OkA: 99.9
OkB: 100
OkC: 1.207
OkD: 1.3
Only thing I can think I did wrong was that the heat sink wasn't fully snapped on to the B side of the MJ transistor on the shunt board during the first check or two of voltage. Could I have fried that transistor, or at least damaged it? The numbers all look right here, so why does the amp have imbalanced channels and sound so unimpressive?
« Last Edit: June 29, 2020, 03:10:55 AM by denti alligator »
- Sam
Reply #11 on: June 29, 2020, 06:12:57 AM
Solder joints.
Reply #12 on: June 29, 2020, 06:15:08 AM
Solder joints.
I've reflowed every one on the B side. I feel at a loss.
- Sam
Reply #13 on: June 29, 2020, 06:17:22 AM
The transistor is not fried.  Good voltages but troubled signal=bad solder joints.
Reply #14 on: June 29, 2020, 06:20:47 AM
OK, I'll go over them one more time. Thanks.
- Sam
