New Crack build, high voltage on T5 and T9
[email protected] · 4569
Offline [email protected]
Reply #30 on: June 30, 2020, 02:17:58 PM
Got it functioning properly finally (sounds great!).
It is a loose connection in the octal socket. I don't yet know if it is the socket itself, the tube or bad connections/solders on the pins.
It is presently stable, though, which is a relief. Are better octal sockets available which are recommended?
Craig Gulla
Reply #31 on: June 30, 2020, 08:35:52 PM
There are many octal sockets that I don't recommend, like the teflon ones, PC pin ones, etc.  You can get the same socket with solder cups, though I like how easily the fork pins in the ones we use can be tensioned if necessary.
Reply #32 on: July 01, 2020, 05:37:24 AM
Ah, good to know! I'll explore tensioning if need be.
Craig Gulla
