Right channel SLIGHTLY quieter than left channel
starnerd67 · 10968
Offline starnerd67
on: August 18, 2020, 06:55:29 PM
Just finished building the base Crack last night.
Sounded great initially. But over the course of time i noticed a slight bias towards the left channel over the right.
Hooked it up to a sescom A/B switch to another amp of mine and could tell that the right channel was slightly quieter.
The end result is that the mid point of sound in the headphones is like half a foot left of center.
Based on https://forum.bottlehead.com/index.php?topic=6931.0
I resoldered as many joints as i could solder but that didn't seem to change anything.
Reply #1 on: August 18, 2020, 07:30:35 PM
How are your DC voltages?  If you plug your phone into the Crack and use the volume control on your phone but leave the level control all the way up on the Crack, how is the channel balance?
Offline starnerd67
Reply #2 on: August 18, 2020, 07:44:59 PM
Resistance Checks:
1 * 2.9
2 * 2.94
3 0
4 * 2.18
5 * 1.94
6 0
7 2.92
8 0
9 2.95
10 0
12 0
13 *15.1
14 0
20 0
22 0
B3 2.92
B6 2.95
RCA L 94.4
RCA R 96.9
Ground 0
Voltage Check
s:
1 75.6 V
2 170.8  V
3 .4 mV
4 170.5 V
5 79.7 V
6 .3 mV
7 98.2 V
8 .6 mV
9 101.3 V
10 .3 mV
Turned the Crack all the way up (volume control from the computer) and there is still a left channel dominance. (that was really scary btw LOL)
« Last Edit: August 18, 2020, 07:51:05 PM by starnerd67 »
Reply #3 on: August 19, 2020, 06:27:24 AM
You may just need to let the kit run for a while to let the tubes settle in.  It's still possible that there's a flaky solder joint or a tube that's not 100% balanced, but letting the amp get 100 hours on it would be a good next step.
Offline starnerd67
Reply #4 on: August 19, 2020, 06:40:05 AM
I guess i'll turn it on and let the tubes burn in
I'll take another pass on the joints later.
If it is an unbalanced tube, is that more common in the output or the pre-amp tube?
Reply #5 on: August 19, 2020, 06:43:51 AM
I would tend to suggest the 12AU7 over the 6080, though it's pretty rare to have an audibly unbalanced tube.
Offline starnerd67
Reply #6 on: August 19, 2020, 07:07:24 PM
Was looking around the forum for additional advice.
I tried playing a 60 Hz tone at max volume and tested the voltages from the tip and ring of the jack.
tip: 10.83V
ring: 10.42V
I'm pretty sure its not the potentiometer cause in incoming and outgoing voltages on both L and R are 1.29V
A2 and A7 are both 1.29V
I kinda get lost on where the L and R go after they go into the tubes though (Im a software engineer not an EE lol)
My guess is that L and R are outputting to A6 and A1 respectively based on the voltages below, and those are the only two that seem to make their way to the output tube.
A1 14.76V
A6 16.44V
(Voltages on both go to zero when the 60 Hz tone stops so i'm fairly certain that these are the L and R)
If that's right. my guess is that it's an input tube imbalance?
« Last Edit: August 19, 2020, 07:17:12 PM by starnerd67 »
Reply #7 on: August 19, 2020, 07:17:38 PM
If your meter is able to resolve AC in the presence of DC, and you have 14.76V AC at A1 and 16.44V AC at A6, that's a difference of almost a dB.
At the jack, that difference drops to 1/3 of a dB.
If anything your power tube may be masking some imbalance related to the 12AU7, which could be the tube itself or a connection that isn't 100% soldered.
Offline starnerd67
Reply #8 on: August 19, 2020, 08:46:06 PM
Are there any joints in particular that i should check since we can narrow down the voltage difference between A1 and A6?
I tried reheating all the joints along the path leading in and out of A1 & A6.
Channel imbalance remains.
(attached images of the input and output tube joints)
Otherwise i guess i'll need to try a new input tube.
« Last Edit: August 19, 2020, 08:52:20 PM by starnerd67 »
Reply #9 on: August 20, 2020, 07:32:13 AM
4L and 5L could be filled with solder pretty easily.
A2 doesn't look soldered.
3L is also pretty crucial and I would want to see the joint reasonably full of solder.
Offline starnerd67
Reply #10 on: August 20, 2020, 03:42:00 PM
I tried resoldering those joints. The jack, A1, and A6 voltages were basically the same as before...
So the channel imbalance continues
« Last Edit: August 20, 2020, 04:59:41 PM by starnerd67 »
Offline starnerd67
Reply #11 on: August 22, 2020, 08:37:55 AM
Just wanted to follow up if any of the previous joints seem off?
I feel like i've reheated and soldered all the joints multiple times now with no difference.
So either i'm overlooking a joint or one of the solders i think is correct isn't.
Voltage and resistance checks still pass.
Reply #12 on: August 22, 2020, 09:22:52 AM
9L might benefit from some extra heat and extra solder.
Offline starnerd67
Reply #13 on: August 22, 2020, 10:45:32 AM
That didn't do it either...  :'(
Well i have some replacement tubes coming on Monday. Hoping those will fix it.
Offline starnerd67
Reply #14 on: August 26, 2020, 03:59:46 PM
So i just got replacement tubes.
Interesting results.
Replacing the input tubes had no noticeable effect.
Replacing the output tube (6AS7G) and right channel sounds right again.
Tested the voltages at the jack to make sure i was hearing things correctly. (60hz at max volume)
tip: 9.5V
ring: 9.9V
A1: 14.4V
A6: 16.05V
So now it's slightly Right Channel dominant. But i wasn't able to really perceive it until checking voltages.
The A1 and A6 terminals are about the same voltages as before. The output is still imbalanced, just in the opposite channel though less noticeable.
Is this an indication that it's the problem is in the Output tube?
