Finished build. Resistance issues. Need help troubleshooting.
vaplen · 5472
Offline vaplen
Hi All,
I just completed my build and thought everything was fine.  The tube glow test worked perfect.  When I tried doing resistance checks I can only read the 0 ohm terminals everything else seems infinite. This is probably bad timing but hopefully someone can give some pointers on how to troubleshoot.  I might reflow everything but I don't know what to do.  I also probably would have powered it on if my readings didn't seem so messed up.  I can also post pictures if needed.
Anyways here are what I measured:
Key:
0 is 0.
1 is infinite when it should be 0.
* is infinite
Terminal
1=0
2=*
3=*
4=*
5=1
6=*
7=*
8=0
9=0
10=*
11=*
12=1
13=*
14=0
15=0
16=*
17=*
18=*
19=1
20=*
21=*
22=0
23=1
24=*
25=*
26=1
27=*
30=~200 Ohms
31=~200 Ohms
32=~200 Ohms
33=*
34=*
35=*
36=1
(I might have measured these wrong. Not sure how to say what the measurement is)
H1= fluctuating between 0 and 1 depending where + probe is placed
H2= bouncing all over the place
H3= bouncing all over the place
H4= bouncing all over the place
H5=bouncing all over the place
H6=bouncing all over the place
H7=bouncing all over the place
H8=0
RCA Jacks
L center pin = 1 Ground tab =1
R center pin =94.8k Ground tab = 0
Hope you all have a wonderful Holiday!
Reply #1 on: December 24, 2020, 10:42:05 AM
Can you post a photo of your meter?
Offline vaplen
Reply #2 on: December 24, 2020, 11:20:04 AM
Thanks so much for the quick reply.
Here is the meter I was using
Reply #3 on: December 24, 2020, 11:23:38 AM
Set the meter to 2000K, then try the resistance readings again that you were having trouble with.
An autoranging meter makes this much easier.  A meter like you have needs to have the range manually selected.
Offline vaplen
Reply #4 on: December 24, 2020, 11:38:48 AM
Yup when I first measured I was adjusting it to the nearest range selection that was available.
Tried 2000k and getting pretty similar results to my initial readings.
Would pictures help?
Reply #5 on: December 24, 2020, 12:52:52 PM
Try putting your meter on 2000 and measure terminal 3.
Posting build photos could help.  Getting an autoranging meter may also be really helfpul.
Offline vaplen
Reply #6 on: December 24, 2020, 01:17:33 PM
Here is the full results using the 2000k selectors (You replied right before I was about to post this).  Also tried terminal 3 on '2000' selector same output.
Also build pic is attached (Tried posting a bunch but apparently hit a size limit or something).  Wasn't sure how to snap them so if you need a better view of the terminals please let me know.
This is exactly how it reads on my meter.
Terminal
1=0
2=1
3=1
4=1
5=1
6=1
7=1
8=0
9=0
10=1
11=1
12=1
13=1
14=0
15=0
16=1
17=1
18=1
19=1
20=1
21=1
22=0
23=1
24=1
25=1
26=1
27=1
28=1
29=1
30=0
31=1
32=1
33=1
34=1
35=1
36=1
H1=0
H2=1
H3=1
H4=0
H5=0
H6=045
H7=1
H8=0
RCA Jacks
R center pin =094 Ground tab = 0
Thank you!
Reply #7 on: December 24, 2020, 01:30:54 PM
How about the DC resistance between ground and pin 9 on each socket?
Offline vaplen
Reply #8 on: December 24, 2020, 01:52:16 PM
I assume that means to use the ohm selector still.
Still using the 2000k selector:
On the A socket depending where I place the probe it shows either 0 or 1.
On the B socket it shows 1
Is it possible that my multimeter is bad?
Reply #9 on: December 24, 2020, 01:54:12 PM
Set the meter to 2000, not 2000K, then try that reading again.
Yes, this may be a meter problem if you are unable to measure the resistor from ground to pin 9 on each socket, as that's all that's there to measure.
Offline vaplen
Reply #10 on: December 24, 2020, 02:04:15 PM
Alright so socket A showed 1259 and B showed 1.  Using the 2000 selector.
Reply #11 on: December 24, 2020, 02:09:30 PM
How about 3, 11, 17, and 25 with the meter set like that?
Offline vaplen
Reply #12 on: December 24, 2020, 02:12:35 PM
All with '2000' selected:
3 is 1
11 is 1
17 is 1
25 is 1
Reply #13 on: December 24, 2020, 02:13:56 PM
1 would mean that you should keep going up in ranges till you don't see the 1 anymore.
I would recommend an autoranging meter though, that was a lot of fussing around to measure one resistor.
Offline vaplen
Reply #14 on: December 24, 2020, 02:17:04 PM
Agreed.
I went all the way to 2000k on the selector and it only showed 1 for each terminal (3,11,17,25).
Of course stores are closed for the holidays right now otherwise I would head out.  Just curious if its something in my circuit causing the issue guess I'll have to wait.
Thanks again Paul.
« Last Edit: December 24, 2020, 02:42:08 PM by vaplen »
