Stereomour II - Right Channel Issue Troubleshooting
vtecths · 44999
Offline vtecths
on: February 15, 2021, 09:44:20 AM
Hello-
Working to troubleshoot an issue on my SII. We recently moved so the amp was packed up. After re-installing the tubes and firing it up, I noticed the right channel was producing only light static but the left channel functioning normally. Tried swapping the tubes around but the right channel remained only producing a light static, which was not volume dependent.
I'm thinking I may have installed the power tubes incorrectly and took something out. I took a round of resistance measurements, which I have attached. First thing that stood out was #10 measures open regardless of volume position but #11 varies like it should. This may explain the dead channel?
There are a few other measurements that aren't quite right (#15, 36, 37, 39, 40 and 45) Each of these measure in millions of Ohms and continuously go down. Not sure if these have anything to do with the volume pot issue.
Any assistance would be greatly appreciated.
Thank you,
Erik
Reply #1 on: February 15, 2021, 10:23:03 AM
You're likely going to find a loose connection that side somewhere between pins 1 and 4 on the 4 pin socket and where the big white biasing resistors mount.
Offline vtecths
Reply #2 on: February 15, 2021, 12:36:43 PM
Thanks, Paul.
I didn't notice anything physically loose but freshened the solder connections in that entire area.
This didn't change any of my previous measurements, unfortunately.
Testing the volume pot itself, I'm unable to get a reading at all from the point that would go to connection #10. Is there a way to temporarily bypass the volume pot
completely to rule out this being the issue?
Reply #3 on: February 15, 2021, 04:05:12 PM
What DC resistance do you get on the volume pot with one probe on the lower rear lug and one probe on the lower middle lug?
How about the the DC resistance between the lower rear lug and the lower forward lug?
A bad volume pot will not cause your resistance problem at terminal 15.
Offline vtecths
Reply #4 on: February 22, 2021, 01:43:20 PM
If I'm understanding you correctly, with the volume in the 'o' position I measure the following:
Lower Rear lug and Lower Middle Lug = 34.87k Ohms
Lower Rear lug and Lower Forward lug = 34.87k Ohms
Reply #5 on: February 22, 2021, 02:51:20 PM
How about lower forward and lower middle?  (Turn the volume pot all the way down for this one)
Offline vtecths
Reply #6 on: February 23, 2021, 01:48:11 PM
With the volume pot at 0, I’m reading 2.1 Ohms.
Reply #7 on: February 23, 2021, 02:22:35 PM
With the volume at 0 (all the way down), lower forward and lower middle should read much higher than that.  With the pot all the way up, that reading would make sense.
If you'd like, you can set your balance and volume pots in the middle of their rotations and play a 60Hz tone into the amp (with the amp off) from your phone with the volume all the way up, then measure the AC voltage between ground and the upper middle, as well as ground and the lower middle lugs of the volume pot.  It should be roughly the same and from most phones it will show several hundred millivolts of AC voltage.
Offline vtecths
Reply #8 on: January 12, 2024, 05:10:55 PM
Apologies, I'm finally coming back to troubleshoot this. Using my MacBook, I've played a 60 Hz tone, full volume with the balance and volume pots in the middle and am only reading 50 mV on both top and bottom middle lugs of the volume pot. Between ground and the outer upper and lower lugs on the volume pot both read 250 mV.
I did notice this evening, the temperature of the 2A3 tube on the faulty
size is running ~100 degrees F cooler than the functioning right side, if this would help isolate the issue.
Reply #9 on: January 13, 2024, 01:08:56 PM
Were the voltage checks OK on this amp?  I see some resistance readings but if you've turned the amp on and tried to use it, a voltage check would preceded that and should have caught what you're describing if it does have to do with operation of one 2A3.
Offline vtecths
Reply #10 on: January 14, 2024, 11:50:59 AM
Hey Paul, I appreciate the follow-up!
I took a fresh round of voltage checks this afternoon. I’ll attach them for review.
I did notice [#7 and #14] along with [#1 and #2] have roughly a 30 volt delta.
Reply #11 on: January 14, 2024, 03:50:01 PM
The 85V where you're supposed to have 58V is alarming.  I would be looking at the two sand cast 5W resistors on that side of the amp up front to see if they are still well connected.  Maybe also check that the 249K resistor is well connected and soldered in that area.
This is almost certainly just a loose connection that has made itself known during the move.
Offline vtecths
Reply #12 on: January 15, 2024, 05:50:02 AM
I've re-soldered all of the 5W sand colored resistors along with the 249K resistors. The 249Ks measure correctly [248k ohms].
I'm able to get audio out of the left channel but now it is softer than the right and it distorts as you raise the volume close to half. Right channel sounds normal to full volume.
I've freshened up the other solder points on that side as well but no dice  :-[
Reply #13 on: January 15, 2024, 05:50:51 AM
Could you post some build photos?
I would 100% not listen to an amp that's this far off on the voltage checks.
Offline vtecths
Reply #14 on: January 15, 2024, 06:08:43 AM
Gotcha, ok. You bet--
